Mudding axles on a YJ - JeepForum.com
post #1 of 14 Old 08-28-2013, 07:00 AM Thread Starter
aslogue4
Just got my 1993 YJ and I need some suggestions for a mudding axle! If you're gonna say don't mud and rock crawl... Don't bother! I'm in Memphis (city know for it's amazing parks)... Not... I'm a mudder!
16 and ambitious! Ready to mod my new to me 93 YJ
#4 First Baseman/Pitcher
Open to suggestions! I will fabricate as much as possible!
I am very capable! Don't doubt me! I will shut you up!
aslogue4 is offline
post #2 of 14 Old 08-28-2013, 07:06 AM
jokerchief462
You got choices. Dana 44s from a waggy. You can go Dana 60s for some serious muffing and rock crawling.
Most go mild beef and lock the Dana 30 and out in a Ford 8.8.
Tons if options most depend on budget and install skills. There is a ton of threads on all
Check out the tech pages for builds some great stuff there.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 14 Old 08-28-2013, 07:28 AM Thread Starter
aslogue4
I have a way to get the 44 but what kind of install mods are required! I can weld but leaves much to be desired?
aslogue4 is offline
post #4 of 14 Old 08-28-2013, 07:38 AM
Carlos14
First you need to ask yourself what kind of tires you're planning on running.
Do you want to run 35s and mud but still be able to street the jeep, ordo you want to run 53" tractor tires like the mud buggies. That will help you figure out what axle you want to go with.
35s= D44s, 8.8,
53s= nothing short of a 1 ton axle. IE: D60
Edit: I don't mud, but I spent enough time in Florida to learn at least this much.
Luck Favours The Prepared
Carlos14 is offline
post #5 of 14 Old 08-28-2013, 07:41 AM Thread Starter
aslogue4
That definitely helped alot! I need it to be street legal! What kind of front-rear axle combo could you run with a 44 rear?
aslogue4 is offline
post #6 of 14 Old 08-28-2013, 07:46 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pick a tire size first. Then axles. Then lift.
Anticanman is offline
post #7 of 14 Old 08-28-2013, 01:54 PM Thread Starter
aslogue4
Well I'm probably gonna do an SOA in the rear but would the Dana 44 be to much for stock leafs? Woul the leafs warp?
aslogue4 is offline
post #8 of 14 Old 08-28-2013, 01:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
post #9 of 14 Old 08-28-2013, 02:35 PM
jimbos76cj
the axles are unsprung weight.. they wont cause your springs to warp. IF your looking to do a spring over keep in mind you have to figure out what your going to do for high steer. Most people see SOA as a cheap and easy 6" of lift but in fact it normally ends up being a nightmare for steering.
Waggy axles will be be 6 bolt so you will need either new rims if you go 44's all around or convert the front to a 5x4.5 bolt pattern. $$$
Also with SOA your going to need to build anti wrap bars for the rear.
Like many of folks here have said the right way to figure out what tpye of axles to use is pick a tire size, then axle then lift.
Im gonna be running a 8.8 rear with a dana 30 front converted over to TJ long shaft. The front will break before the rear.
You say you want to mud it then drive it on the street. What size tires you run will dictate what gear ratio you need and how strong an axle you want.
88 YJ 35's 8.8 rear, family style roll bar, ax-15 external slave conversion, Custom double D fab dash 4" of lift taurus fan, Head light wiring upgrade, MSD 6al, JB conversions SYE, 258 with RV cam, Long tube headers, Borla exhaust. 1"mm, Auto meter gauges.
jimbos76cj is offline
post #10 of 14 Old 08-28-2013, 04:58 PM
fratis
fratis's Avatar
v8 crate
9" thirds with portal boxes front and rear.
rework front of frame to get steering as high as possible.
JK steering box with hydro assist.
ori struts with 3 link front. brackets above frame and level with axle tubing. Links bent up and out of way.
flat/semi flat skid.
What you want to do is concentrate on removing drag. Basically when in the mud you are plowing your way through. Those that push more have a harder time until they loose momentum and stop. You want to eliminate all the things that will grab and hold on to the mud. The portals will get the axle tubing up higher. The link suspension will not have the leaves out front to push through. The ORIs will have a narrower profile then coils. The links can be bent up and not drag so deep. Figure out whats going to catch the mud and rework it.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #11 of 14 Old 08-29-2013, 01:47 PM
jred
If you're planning on running the Cov. Pike bottoms, I hear those mudholes are DEEP.
jred is offline
post #12 of 14 Old 08-29-2013, 02:14 PM
Jeepsr4me
My suggestion, Buy a rig ready to go... What you are about to attempt is going to require welding and fab work to get things right.
Forget any axle mod or any mod till you know what size tires you gonna run.
Jeepsr4me is offline
post #13 of 14 Old 08-29-2013, 02:37 PM
rykemc
I have a feeling this isn't going to turn out well.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #14 of 14 Old 08-29-2013, 05:59 PM Thread Starter
aslogue4
I'm not running the bottoms! I'm running my farm in millington don't worry about me!
aslogue4 is offline
