MSD 6A tach failure - JeepForum.com
post #1 of 14 Old 04-03-2013, 09:54 PM Thread Starter
whiskeywiz
MSD 6A tach failure
Installed the MSD 6A with flamethrower ignition and taylor 8mm wires. Tachometer does not work. Input?
Thanks
whiskeywiz is offline
post #2 of 14 Old 04-04-2013, 06:41 AM
blown50
1987 YJ Wrangler
Thanks
The easy way is to get the msd tach adapter! I tried other ways and did get it to work, but it wasn't accurate! Get the adapter, saves a lot of head scratching
blown50 is offline
post #3 of 14 Old 04-04-2013, 11:40 AM
tom_sprecher
This one worked perfectly on the race car.
Get the adapter.
Tom
tom_sprecher is offline
post #4 of 14 Old 04-04-2013, 08:28 PM Thread Starter
whiskeywiz
Buddy is suggesting building the adapter, depending on if the voltage is linear to the rpm's? For now I'll let him take a look and see if he can save me fifty bucks.
post #5 of 14 Old 04-04-2013, 09:36 PM
timatoe
timatoe's Avatar
MSD swears you don't need the adapter. I call BS cause mine never worked when I had the MSD, I'd just buy the adapter.
timatoe is offline
post #6 of 14 Old 04-04-2013, 10:13 PM Thread Starter
whiskeywiz
What's messed up is the very easy to read instructions showing 2 different installations for AMC motors both utilizing the tach horsehoe. How can installation be so simple with no indication of any issue, and not work because an unmentioned adapter is required? A real kick in the balls...
post #7 of 14 Old 04-05-2013, 06:58 AM
blown50
1987 YJ Wrangler
You don't have to have the adapter, I got mine to work without one! But it didn't read correct. Some people like to take the long path (like me). In the end for it to work rite, the adapter will have to be used. Or a adapter!
blown50 is offline
post #8 of 14 Old 04-05-2013, 07:42 AM Thread Starter
whiskeywiz
Cant fathom why tach functionality wouldnt be built into the unit. As if only Porsches have tachs. Silly.
post #9 of 14 Old 04-05-2013, 11:59 AM
blown50
1987 YJ Wrangler
It is for aftermarket tachs, but the jeep has shall I say a voltage sensing tack ( I don't want to explain the operation of the tach) I went thru several hours figuring it out! In the end I got the tach adapter! Just thought I would save someone a headache By the way, the loop wire on the 6a will have to be cut for it to register rite
blown50 is offline
post #10 of 14 Old 04-05-2013, 01:36 PM
USMCBuckWild
I have head several vehicles withthe MSD 6 box and every single one of them didn't work worth a ***** when it came to the tach. Even the Digital 6 in the Duster didn't work properly. I had to get the tach adapter for everyone of them.
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #11 of 14 Old 04-05-2013, 05:55 PM Thread Starter
whiskeywiz
"91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot."
I know what you mean, if I ever see my 89 YJ's previous owner I'll give him a sweeping right hook to the head and a boot to the body.
post #12 of 14 Old 04-05-2013, 05:59 PM Thread Starter
whiskeywiz
not because I'm mad, but because he deserves it
post #13 of 14 Old 04-05-2013, 06:14 PM
USMCBuckWild
This!!
I traded a Gorgeous 74 Duster with a 612 hp stroker smallblock, brand new paint, built trans, built Dana60 rear and complete interior for my YJ and $3,000. He lied to me about the trans, engine, front end, rear end, lift, body, wiring, roll bar. Basically lied about EVERYTHING.
The old saying "Putty and paint will make it what it ain't" was true. I thought I did pretty good on the deal; a week later I threatened his life.
post #14 of 14 Old 04-05-2013, 07:16 PM Thread Starter
whiskeywiz
I sold my 88 mustang, pretty much stock, clean, no rust, taken care of, to buy a Jeep. I do not regret selling the 'stang, after 7 years of ownership I was at a point with it that it needed a bunch of money put into it to keep up with the Hondas and I always wanted a Jeep so I sold it.
I went out a few weekends with cash in hand and a car trailer all over to buy Jeeps that turned out not to be what they appeared online. One ******* in Ohio had two different length axles on this thing and tried telling me it was "widetrack".
So I was getting frustrated and bought my YJ that looked worth the $. Turns out the transfer case was WASTED, I mean an inch and a half of slack in the chain and therefore gears smoked. So I replaced that. Then I discovered that the rear wheels weren't centered in the wheel wells. LEAF SPRINGS MOUNTED 180 DEGREES BACKWARDS
Latest discovery was the manual choke being mounted backwards, (lever out = no choke, lever in = choke), after driving it for a period of time with the freaking choke on
Also he put a fuel filter on that didn't have a breather valve so he cut the breather hose short and let hang so when I filled the tank it came pouring out the hose.
Don't know what it is with Jeeps, but some real dickweeds sell them
