MrDad has no dash, parking, brake, or head lights - JeepForum.com
post #1 of 12 Old 03-09-2010, 11:15 PM Thread Starter
MrDad
Subject: '89 Wrangler, 4.2L
Need help with: Dash, parking, brake, and head lights.
Chief complaint: Lights stopped working from one day to the next.
Possible culprit: Alternator had been overcharging at highway speeds and I had to run headlights to bring guage down from red zone during commute. Did this for a few months.
Actions taken to remedy so far: replaced head light switch, relay, cleaned all grounds, checked all fuses, cleaned battery posts, and replaced alternator.
Problem: still no lights.
Any possible suggestions to seek a solution to my problem is greatly appreciated.
MrDad is offline
post #2 of 12 Old 03-09-2010, 11:28 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Did you check your fusable links??????? should be down on the fire wall between the block and batt. They go to the starter relay. One of them feeds power to all of the lights.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 12 Old 03-09-2010, 11:43 PM Thread Starter
MrDad
Hmmm...found fusible links you spoke of, but how are they accessed to see if they need replacing? The black "rubber housing" around fuses looks like they need to be cut open to view. Thank you for the suggestion, I had not known about this possibility.
MrDad is offline
post #4 of 12 Old 03-10-2010, 07:00 AM
Elsahara
I did not have the "cut" the fusible link to get it out, on my 90 4.2 when it blew.
I did however need to clean it find where it opened and pop off the cover and replace the fuse. Sorry i cant explain it well or give you more info. This was.....6...7 years ago. I looked on google for a pic but came up empty.
Elsahara is offline
post #5 of 12 Old 03-10-2010, 07:22 AM
K4KAS
To check a fusible link, pull on it in increments and see if it stretches. If it stretches, you found the blown link.
Did you check all the bulbs? 12 volt alternators can put out up to 20 volts unregulated. Thats enough to blow all bulbs.
K4KAS is offline
post #6 of 12 Old 03-10-2010, 07:28 AM
rustywrangler
I do the stretch test as well.
post #7 of 12 Old 03-10-2010, 07:30 AM
Elsahara
so apparently mine was not oem...
Elsahara is offline
post #8 of 12 Old 03-10-2010, 09:17 AM Thread Starter
MrDad
Thank you all. I will perform this test next chance I can get to it. Ironically, this morning I go to take daughter to school and Jeep won't fire up. I went to last place I worked on and jiggled the starter fusible link wire and it fired right up. I know now where my problem area is. My next question is: how do I replace these fusible links, and is it a complete wire assembly, or do I simply replace inline fuse? I am new to this repair and remain clueless.
You all have been a tremendous help! I love this place!
Thank you.
PS.
Wires seem rubbery and very soft.
MrDad is offline
post #9 of 12 Old 03-11-2010, 05:54 PM Thread Starter
MrDad
Ok Jeepers....here goes....time to cut some wires. WIll post results after attempt.
MrDad is offline
post #10 of 12 Old 03-11-2010, 08:08 PM Thread Starter
MrDad
And the Jeep gods said....Let there be light!
Thank you rustywrangler and all. I can drive past dusk now.
Thank you, sincerely, MrDad
MrDad is offline
post #11 of 12 Old 03-12-2010, 08:22 AM
K4KAS
Glad you got her fixed! Thanks for checking back with us!
K4KAS is offline
post #12 of 12 Old 03-12-2010, 09:33 AM Thread Starter
MrDad
Anytime K4. Your test for finding a failed fusible link worked. I found the damaged fuse immediately after performing the test.
It was definitely a team effort and this forum gets all the credit. Thanks again to everyone.
I plan on visiting this site a while. I am in the process of reviving my old '89 back to par after I almost sold her for $700. What a mistake that would've been!
See you around!
MrDad is offline
Parking and brake lights dont work jmathis2 YJ Wrangler Technical Forum 0 08-14-2009 02:10 PM
Parking Lights/Dash lights out jjmiller81 TJ Wrangler Technical Forum 4 01-21-2009 03:17 PM
No dash lights, tail lights or parking lamps BlkBird TJ Wrangler Technical Forum 5 01-11-2008 09:03 PM
No Lights after Stereo Install, (Dash, Parking, Brake), presets dont save either NaptownWrangler YJ Wrangler Technical Forum 3 04-13-2007 08:04 AM
Parking lights,fogs and all dash lights out? Drew99 TJ Wrangler Technical Forum 3 11-08-2003 01:32 PM
