Mpg - JeepForum.com
post #1 of 27 Old 04-07-2013, 03:23 PM Thread Starter
Gage56
Mpg
What do you guy's get ?
this is mine not sure what size tank all i know is its plastic. When i filled up the needle was way past the full mark too
1992 YJ
Gage56 is offline
post #2 of 27 Old 04-07-2013, 04:05 PM
Rich8earnhardt
!994 2.5L 5spd
i get about 18 to 20. Some times more if its a long highway trip
Rich8earnhardt is offline
post #3 of 27 Old 04-07-2013, 04:06 PM
pete1991YJ
The stock tank is about 15 gallons. I'm getting around 20 MPG's with the 4-cylinder and 5-speed, stock gears on 31" tires. Keeping it tuned up and no vacuum leaks makes a world of difference.
110 miles on 1/2 a tank isn't too bad, but not the greatest either. I usually try for 150 miles on 1/2 a tank.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #4 of 27 Old 04-07-2013, 04:16 PM Thread Starter
Gage56
Yeah guess i forgot to mention mine is a 92 4.0 5sp 33/12.50/15 3.07 gears ?
1992 YJ
Gage56 is offline
post #5 of 27 Old 04-07-2013, 04:27 PM
pete1991YJ
Hrmmm... not bad with your setup. You *might* be able to squeeze 1 or 2 more MPG's out of it, or maybe not. Basically getting 15 MPG's with the 4.0 is average. Those 3.07 gears must be PITA tho with the 5-spd and 33's.
post #6 of 27 Old 04-07-2013, 04:30 PM Thread Starter
Gage56
Yeah but its all good i have a D30 with 4.10s and a 8.8 with 4.10s to go in when i start the rebuild
1992 YJ
Gage56 is offline
post #7 of 27 Old 04-07-2013, 09:12 PM
Xpress
Usually you will find most are averaging 15-16mpg with the 4.0 and 17-18mpg with the 2.5.
I was averaging 18mpg with my 2.5 on 29" tires, stock gears.
All about that unibody life.
Xpress is offline
post #8 of 27 Old 04-07-2013, 10:11 PM
jeepyj13
Well I never calculated my Mpgs but my yj has a 4.0 3sp auto crappy 3.07 gears riding on 33s. The tank is 15gals. I took it on a hilly 135mile road trip to mississippi state university one weekend and made the trip with about 1/2 a tank of fuel to spare. I maintained 65-70mph throughout the drive. I was very surprised. It did better on gas than I thought.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #9 of 27 Old 04-07-2013, 10:27 PM
indiobill
i have a 4 banger with 4.88 and 33s. i get about 15 to 18 on the street but can go all day in the desert. just dont use much gas out wheeling
indiobill is offline
post #10 of 27 Old 04-08-2013, 09:51 AM
flea1987
2.5 5speed stock everything, getting about 19, but I keep the rpms around 2500 or less when I can
flea1987 is offline
post #11 of 27 Old 04-08-2013, 11:04 AM
Reno72
Driving a 2500HD I've learned to drive with a light foot, the increase in MPG can be significant. Since getting my 92 4.0 ready to pass smog I've changed anything that would help. I'm getting 18 around town with 32/11.5 tires, 5 speed, 3.73 gears.
Reno72 is offline
post #12 of 27 Old 04-08-2013, 11:18 AM
pete1991YJ
FYI my old 1979 K20 (old-school 3/4 ton 2500) got 8 MPG regardless of what you did. I put in a 396. 4.10 gears, 14-bolt detroit and a 4-speed.
Going downhill with a tail wind, it still got 8. Uphill, it got 8. In 2 wheel drive it got 8. In the snow it got 8.
It got 8.
The new trucks are nice.
post #13 of 27 Old 04-08-2013, 11:58 AM
Reecycup95
I have a 95 2.5L with a 4spd out of a cherokee..sittin on 35s...bout 17-19 miles a gallon..better than my truck so it gets drove a good bit
Reecycup95 is offline
post #14 of 27 Old 04-08-2013, 01:36 PM
Reno72
It got 8.
Yes the new 6speed helps a lot. I can get 12-13 around town, maybe 15 on the Hwy. When I hook it up to the toyhauler it's 8-9 MPG doesn't matter uphill or down, it is what it is.
Reno72 is offline
post #15 of 27 Old 04-08-2013, 02:23 PM
idiot magnet
You should check out the 15 to 20 gallon simple fix for the 4cyl YJ's. Very easy to do and less trips to the gas station.
Are you adjusting your mpg since your speedometer is not correct after adding the larger tires?
When I had my 4 cyl YJ I got 18-19 mpg.
idiot magnet is offline
