Moving the brake lines - JeepForum.com
post #1 of 2 Old 04-24-2002, 09:55 AM Thread Starter
wckdyj
Has anyone moved their brake lines to under the frame? I have a 89 YJ. Do you have to bleed the brakes at all?
89 YJ 2.5L, 2" SRS, 1" BL, 31-10.5-15MT's, Rockcrawlers, rocklights, 1992 roll bar, TJ Flares, LED's
For the best prices on parts and all your fabrication needs, call us at (610) 358-3179 or visit us at www.upnover.com
wckdyj is offline
post #2 of 2 Old 04-24-2002, 08:34 PM
osburn
osburn's Avatar
Yes and Yes. You'll have to disconnect the line to run it under the frame. I suppose you could disconnect the caliper from the rotor, loosen all the body mounts, lift up the body and push the caliper between the inner fender and the frame! <img border="0" title="" alt="[Wink]" src="wink.gif" />
Matt Osburn
Score 1032
osburn is offline
After replacing calipers and rubber brake lines, my brake is still stuck! Dmcastino TJ Wrangler Technical Forum 23 06-25-2009 11:21 PM
Moving the third brake light 00JEEPTJ69 TJ Wrangler Technical Forum 3 12-16-2008 08:35 AM
Hard Brake lines(not soft lines) Nonya TJ Wrangler Technical Forum 0 09-04-2007 06:33 PM
Stock brake lines don't bolt up to Van's Big Brake kit Red_ TJ Wrangler Technical Forum 6 06-17-2007 10:11 PM
Moving the emergency brake?????/ Dozer. TJ Wrangler Technical Forum 3 08-15-2005 04:21 PM
