Moved to Wy and Jeep feel weak on highway mountain passes...? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Moved to Wy and Jeep feel weak on highway mountain passes...?
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Looking for a rear bumper for your JK? Check out what JcrOIntroducing the Dagger, JcrOffroad's new Slimline bumpers.
Unread 07-27-2009, 11:41 PM   #1
GCarpJeep
I've noticed since i've been in wyoming that my YJ feels weak on the uphill mountain passes here (coming out of Laramie towards Cheyenne, if anyone is familiar). I've had to put it in 3rd and jam the gas pedal to get up the hills and stay at a reasonable speed (which is still 20 under!!!). it has a Howell Fuel injection system and the manual doesnt say anything about adjusting to elevation. I'm going to check my plugs to see if any are fouled up 2moro since i drove it from Pennsylvania.
Does anyone else have any suggestions, or are these just the woes of owning a YJ? i hate having to be on the highway in 3rd gear to stay at 55-60 mph up hill when the speed limit is 75. seems like a 4.2 ltr engine should be stronger... (btw, i'm only running 30" tires)
GCarpJeep is offline   Reply With Quote
Unread 07-27-2009, 11:46 PM   #2
GCarpJeep
also, i was reading in another post about "bad gas". the fuel tank was changed about two months ago and the Howell came with a new sending unit.
i have a feeling i'm goinna be told to regear or deal with it...
Unread 07-28-2009, 12:31 AM   #3
provinT13
Fuel filter? Cat?
2 Hands Working Do More Than 1000 Hands Praying
94 YJ Build
99 TJ Build
provinT13 is offline   Reply With Quote
Unread 07-28-2009, 04:20 AM   #4
buckshot500
If you haven't done the Nutter Bypass yet, & you are still running through the on-board computer your in luck!
Click the view key at the top of your screen & then zoom in a few times.
Originally Posted by 5point1 View Post
Well after I drained the oil, I ran water through the engine to clean out the gunk. (the guy who owned before me obvioulsy didn't know how to maintain the engine).
90YJ98XJ
buckshot500 is offline   Reply With Quote
Unread 07-28-2009, 06:06 PM   #5
FarmBoy
You lose something like 5% of your HP for every 1000 feet you are up in elevation. If you're ay say 3-5000 feet you could have lost 20% of your HP compared to what it was at sea level.
-jeff b.
1995 YJ 4 cyl auto, 2" BDS springs, BDS shocks, and 1/2 lift boomerang shackles. 31" BFG Mud Terrain.
FarmBoy is offline   Reply With Quote
Unread 07-28-2009, 06:08 PM   #6
Mean Max
Don't poke the bear
Mean Max's Avatar
I'll bet you're running a bit "lean" on the jetting now that you're at a higher elevation.
Almost all carbed motorcycles must re-jet for higher elevations.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 07-28-2009, 06:21 PM   #7
Louie4
Injanir
Louie4's Avatar
Max
I think he's running the Howell Fuel Injection kit.
Lou
Poison Spyder Fender Install
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote
Unread 07-28-2009, 06:24 PM   #8
Mean Max
Don't poke the bear
Mean Max's Avatar
DOH!
As I just said in another post, I need more "idiot-proof" things around me.....like maybe some threads that read themselves to me.....
Max
Unread 07-28-2009, 06:27 PM   #9
Louie4
Injanir
Louie4's Avatar
Originally Posted by jacylin View Post
I think you're spamming. I don't need new kicks.
I'm sure you'll be banned soon.
Lou
Unread 07-28-2009, 06:31 PM   #10
xxxflhrci
I have owned more than one 4.2 Jeeps nd would guess that your mountain performance is pretty much normal. Sure, they have plenty of torque, but only 112 or so hp. You can't expect steep grade pulling peformance out of them when it comes to speed.
xxxflhrci is offline   Reply With Quote
Unread 07-28-2009, 06:37 PM   #11
UnFocused
You probably should adjust your timing as well for high altitude. The factory spec calls for 16* as follows:
http://home.sprynet.com/~dale02/ignition.htm
from this site:
http://home.sprynet.com/~dale02/list.htm
You may get a better set on the timing by tuning it by vacuum rather than the timing marks. It’s worked for me over many decades and altitudes and accounts for both engine wear and altitude. I operate with the same engine at 8500 feet and my timing is at 19* BTDC with no problems, plenty of power, and 18.5 to 21.6 mpg.. Here’s how you do it:
http://home.sprynet.com/~dale02/wiretrik.htm
also from the second link above. You might want to cycle the distributor 2 or 3 times to find the max vacuum and lock it down on the final cycle. Last make sure your air intake is really free flowing; the major problem is lack of air at altitude. If there’s a low restriction air filter available for your air cleaner by all means get one.
Good luck!
UnFocused is offline   Reply With Quote
Unread 07-28-2009, 06:49 PM   #12
jeeepguy
This is more than correct. I have two 4.2L YJs right now and they both run the same as yours. My stroked YJ roars over the passes and my XJ with a stock 4.0L with 200000+ miles runs over the passes easily at 70+.
If you have an original 4.2L engine with typical year miles (200000+), you will have probably 40-50bhp, even with the Howell FI. Also, you didn't mention if the head was replaced or is it the original 4.2 head? Makes a HUGE difference.
Put it on a dyno and you will see.
Conclusion... you have a tired 4.2 and you will not be able to do anything about the climbing power until you replace the engine. Period.
Good luck...
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline   Reply With Quote
Unread 07-28-2009, 08:33 PM   #13
1998zj
I have climbed that pass many times. You are at 8400' by the time you see Lincoln. I had a 3.0 liter Ford Ranger that used to struggle up there too. I think you are doing ok to be going 60 up the hill. The 4.2 doesn't make much more horsepower than my 2.5.
"Our lady of blessed acceleration don't fail me now"
1998zj is online now   Reply With Quote
Unread 07-28-2009, 11:01 PM   #14
GCarpJeep
thanks for the responses. it is the stock head on the engine. would i replace it with a 4.0 head. also, my engine has about 135,000 miles on it. i'd love to replace the engine, but i have to do it as economical as possible. nothing fancy, i'm on a college budget. maybe something where i can retain the transmission, axles, etc...
guess its gonna take some saving and i doubt i'll be driving fast in the winter anyway.
Unread 07-29-2009, 04:17 AM   #15
buckshot500
In post number 4, I was trying to refer you to info concerning the "high altitude jumper wire" that is located under your dash near the glovebox. Try it, it might help!
90YJ98XJ
