Quantcast Mounts not lining up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Mounts not lining up
Old 01-11-2009, 01:02 PM   #1
Macklin96
I am trying to set a 4.0 out of a 95 xj in my 94 yj. Been running into little problems all day. Now i have the engine in the jeep still being supported by the hoist. I put the new motor mounts on the frame mounts and bolted it to the engine. For the last hour i have been tryng to position it so that both frame mounts sit flat against the frame. I have the passanger side on and c-clamped so it can't move away but the driver side will not sit rite. when i hold up the mount the way it is supposed to sit it is about an inch and a half away from the frame. It looks like the motor mount bracket that is hooked to the 4.0 needs to be longer. It actually is long enough but the bolt hole is too far towards the engine. What am i doing wrong?
Macklin96 is offline   Reply With Quote
Old 01-11-2009, 01:22 PM   #2
visa
the 2.5L yj and 4.0L wont set in the same place the motor mounts that you have, did you buy them or make them, cause i dont think any company makes them?
visa is offline   Reply With Quote
Old 01-11-2009, 01:24 PM   #3
Macklin96
Ordered them from dealer and the mounts are brown dog
Glock Forum
