Mounting a Warn 8274 - JeepForum.com
post #1 of 9 Old 02-20-2012, 11:00 PM Thread Starter
imstillatwork
I'm picking up an old-but-working-fine Warn 8274 tomorrow ($150-someone owed a friend a deal, and I get to take advantage of it.) I haven't got a chance to see if it's a 8274-50 or not.
I've never installed a winch before. It has cable and remote. I might be able to score the mount from whatever it was on before and fab something up?? don't know - haven't seen it yet.
1) What size power cables should I use? Will 1/0 welding cable be enough?
2) Does anyone think removing the front cross brace and sinking the winch between the rails is a terrible idea??
Found this pic but it was from a 2008 post in another forum.
imstillatwork is offline
post #2 of 9 Old 02-21-2012, 05:17 AM
Louie4
My buddy bought this and welded it onto his CJ bumper. He had to add a plate to the top but it worked out great.
http://www.tmrcustoms.com/store/index.php?main_page=product_info&cPath=3_29&produc ts_id=416
Pics of it installed, though not very good.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 9 Old 02-21-2012, 09:09 AM
skyj
I just got done building this for my winch.
Here it is installed.
skyj is offline
post #4 of 9 Old 02-21-2012, 04:19 PM Thread Starter
imstillatwork
I just picked it up today. Rough on the outside, but functions perfectly. Cable is in great shape.
It was mounted on an OLD jeep (60s?) with a home-made hack job 1/2 inch thick base, front plate and gussets. I passed. way to overkill for me.
A friend had an extra front mount winch plate that might work. It might be a bit too narrow, will it be ok to bolt it to a flat plate that is bolted to the frame?
can't wait to tear the thing apart and clean & paint it up.
post #5 of 9 Old 02-21-2012, 05:13 PM
Louie4
There are a lot of rebuild threads and videos for that particular winch. If I could I'd trade my rebuilt M8000 for an old M8274, working or not. For the mount you just need to make sure the feet are bolted to a vertical plate. I would get one of the mounts everyone on here is suggesting and welding it to the top plate of the bumper. Something to that effect at least.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 9 Old 02-21-2012, 06:31 PM Thread Starter
imstillatwork
That sounds like the plan, thanks a lot. If what I have doesn't work out I'll grab one of those mounts.
post #7 of 9 Old 02-21-2012, 07:15 PM
panaceabeachbum
I sure would like to find an 8274 I could afford
panaceabeachbum is offline
post #8 of 9 Old 02-21-2012, 10:21 PM
bigmeangreen
guess im lucky... I have one on my yj and it pulls great. Dont really know what gauge wire i used... it was old welding cable. haha... just make sure your pulling cable it put on correctly b/c if not birdsnest are a pita. Oh yeah it will hold 150 ft thats why they are popular. I would really like to know were that guy got the front bumper OP... but i might have to make one.
'95 Wrangler Rio Grande. Warn 8274 winch, Rock hard rear bumper.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)--o--)_) Virtus Junxit Mors Non Separabit
bigmeangreen is offline
post #9 of 9 Old 02-21-2012, 10:59 PM Thread Starter
imstillatwork
The photo is from tkotrailriders.com but I can't find the post.
I like the idea, but too much work for me
I torn the winch apart this evening and although it's pretty decroded on the outside from the Oregon weather, the insides all look very, very nice once I cleaned out the rusty oil water.
Brake rings were thick, brushes look like NEW, brush braids are shiny and nice, armature is pretty darn clean, and the commutator only had minimal crud in the grooves.
The only thing I'm not sure about is the first reduction gear off the motor has a lot of lateral play on the shaft, but otherwise the bearings are tight (no off axis play - wrong terms I'm sure.)
The cable is 150 3/8 and looks like it's been unspooled only a few times. the lower layers are super nice. I found no kinks or fray anywhere.
Totally stoked!
Warn 8274 lvzfyr Wrangler General Discussion 6 06-28-2010 11:34 AM
Warn 8274 and ARB Bull Bar Strebs TJ Wrangler Technical Forum 3 06-02-2009 08:25 AM
Warn 8274.... 89_Jeeper YJ Wrangler Technical Forum 5 11-27-2006 07:45 PM
warn 8274 help garrynakamura TJ Wrangler Technical Forum 2 06-29-2005 01:39 PM
Get rid of the WARN 8274 or KEEP IT?? RescuedJK TJ Wrangler Technical Forum 13 05-04-2005 01:02 PM
