Quantcast Mounting a new rear bumper on my 93 YJ... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Mounting a new rear bumper on my 93 YJ...
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 03-26-2008, 09:29 PM   #1
trwrangler
YJ Wrangler
Want to build a new rear bumper with two recovery points and a reciever for my 93 YJ. Question is how did you mount that new bumper??? Looking for some ideas. thanks...
trwrangler is offline   Reply With Quote
Old 03-26-2008, 09:40 PM   #2
99dime
i used a 10" piece of 3" flatbar, 3" square tube cut 1.5"
88 YJ 6cyl
95 "Family Style" Roll Bar
3.5" Tuff Country susp lift
2" BL
Dana 30,35
15x8 Ultra 164 wheels, 32x11.50 tires
99dime is offline   Reply With Quote
Old 03-26-2008, 09:50 PM   #3
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I intend to just replace the rear crossmember like what is done in this thread: http://www.jeepforum.com/forum/f12/custom-rear-frame-cross-member-442274/
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 03-26-2008, 10:45 PM   #4
whiteyj1994
I just checked out that thread and it definitely would solve a ton of problems for me, I almost tore my receiver out on my last trail run pulling a expedition out of a snow hole. I will start rounding up parts for my crossmember next weekend
whiteyj1994 is offline   Reply With Quote
Old 03-27-2008, 07:17 AM   #5
jeepwrnglr92
Here are soem pictures of my bumper build.
http://s171.photobucket.com/albums/u317/corvettejoe/rear%20bumper%20build/
For sale 1992 YJ Wrangler: Hurculiner, bestop Safari top.RC 4" lift 32 AT wheels, custom bumpers,
2000 Corvette Roadster: Almost stock
http://www.demonoff-road.com/
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline   Reply With Quote
Old 03-27-2008, 11:03 PM   #6
trwrangler
YJ Wrangler
I appreciate the replys, but what I'm really looking for is how you attached the rear bumper. Did you simply bolt it up to the thin factory bumper, remove the old and fabricate new hangers or what. Just want some of your ideas, and any pics.
Old 03-28-2008, 09:26 AM   #7
trwrangler
YJ Wrangler
bump
Old 03-28-2008, 11:00 AM   #8
Sambox
If you want a strong mount, attach it directly to the frame. Weld some c-channel perpendicular to the bumper (parallel) to the frame and then bolt that to the frame in several places on each side.
The c-channel is stronger that flat bar.
"Jeeps are the equivalent of barbies for men."-JaikYJ
1996 Cherokee XJ, All stock except for a Flow Master exhaust.........for now. He He.
http://www.cityprofile.com/forum/tucson/
Sambox is offline   Reply With Quote
Old 03-28-2008, 11:01 AM   #9
Sambox
Do NOT bolt it to the old bumper.
Old 03-28-2008, 09:04 PM   #10
trwrangler
YJ Wrangler
The problem is with the body mount bolts, and the fuel tank mount with the fuel tank shield that is bolted directly to the old original bumper. I'm looking at maybe fish plating the frame on the outer side and the bottom side where there is a threaded 7/16 hole to be used, it is on each frame rail, along with a gusset running from the frame to the new bumper outer side of frame due to the fuel tank with minimal clearance and not allowing for any gusseting on the inside of the frame. If anyone has any ideas I would like to hear them. thanks.
Old 04-01-2008, 08:21 PM   #11
whiteyj1994
aside from replacing the factory cross member, which may not be necessary, I have been looking around at other jeeps for ideas myself and the only idea I have come up with is to relocate the rear shakles to under the frame like on a cj7 and possibley use c-channel with gussets behind the factory cross member then bolt my home built 2x4 bumper to the factory location. the c channel would cover the old shackle hole and I would add a second for another through bolt, possibley even weld them in place. does anyone see any pros or cons to any of that?
Old 04-02-2008, 03:17 AM   #12
northjeep
Jeep parking ONLY
northjeep's Avatar
This is what I did as part of a frame repair.
I deleted the factory rear crossmember.
Welded the bumper on the frame.
Plenty of space for my 1 1/4" angle to mount up the rear of the tank (not pictured as of this writing).
Bolting to the stock sheet metal rear crossmember is a recipe for disaster with anything substantial bumper wise.
http://www.jeepforum.com/forum/f12/l-k-what-i-found-pics-524638/
-NorthJeep - >> Just Enough Essential Parts
RED Jeep Club member - YJ Club - 258's Unite
northjeep is offline   Reply With Quote
Old 04-02-2008, 10:16 AM   #13
jeepthrill85
I'm in the same stages right now of reinforcing the rear bumper area. I can say, from the PO's experience and what he left me with, that the stamped piece of tin at the back is useless! It'll be gone in favor of a new beefier bolted on piece.
jeepthrill85 is offline   Reply With Quote
Glock Forum
