After sinking my 94YJ twice in 24 hours (first time was with my daughter what an intro to Jeepin. the 2nd time was on a first date, helluva good impression )
After retrieving my HiLift jack from my CJ8, and getting myself out, I decided to mount it on the YJ. I have a hard top so interior mounting would be difficult. A winch will be on the front Sunday (a little 2 late) That leaves the rear. Any ideas?
I have a SteelHorse RocCrawler rear bumper with tire carrier on my Jeep .. looks good, but no place for my HiLift either.
I am going to be making a new tirecarrier for the back with a HiLift mount. Quick, simple, easy to do with a cutter, grinder and welder.
Another thing that people have done is use some angle-iron, drill a bunch of holes, and mount the angle-iron into the original Bumperette location, then bolt the HiLift to the angle-iron .. If you have the equipment, easily done in under an hour.
On a yj the front cross tube between the frame rails will hold the upright portion of a highlift jack. Just pull off the base and rachet and put them inside under your seat. Drop a pin in a hole drilled in the cross tube to hold the highlift in. I've never tried this but I saw one once. It looked like an easy way to carry the highlift and yet keep it out of the way.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
