mounting CJ style mirrors help - Page 2 - JeepForum.com
post #16 of 21 Old 02-14-2013, 12:23 PM
NonRubicon
Originally Posted by ggarland View Post
I just thought of another question. The screws coming out of the hinge has beveled heads and the hole is counter sunk to match the head. Is there any kind of insert that can be placed in this hole to make it flush with the hinge? My mirrors have flat mounting brackets and when I put the bolts in and tighten down on them they pull into the bevel and warp the bracket. If anyone knows of such an insert or some other way of filling this in could you please share where to find it or how to fill it?
Thanks.
You can just use a regular flat/flush mount bolt for those spots, it doesn't need to be the original tapered-head bolt. Use hex or torx style for the replacement, whichever you prefer.
NonRubicon is offline
post #17 of 21 Old 02-14-2013, 01:53 PM
NHfireLJ
NHfireLJ's Avatar
NHFireYJ - I love those fenders! Does your name indicate that you are in the fire service in New Hampshire?
Oops, before I asked that question I should have noticed the IAFF sticker on your window.
The fenders are C&C Fab on ebay..he will make any width. its a DIY kit...
Thanks
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #18 of 21 Old 02-15-2013, 05:44 AM
ggarland
NonRubicon - I am using regular bolts with button type Allen heads but they still pull down into the counter sink and cause the bracket to bend. I was hoping someone would know of some kind of nylon or plastic piece that would fill in the hole.
NHfireYJ - Do you have a link. I looked for them last night but couldn't find them.
Thanks all.
ggarland is offline
post #19 of 21 Old 02-15-2013, 05:48 AM
NHfireLJ
NHfireLJ's Avatar
Thanks all.
For the bolts just use a washer slightly larger than the countersunk hole.
C&C on ebay has a different user name.... Here.
http://www.ebay.com/itm/Jeep-tube-fr...20900128514%26
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #20 of 21 Old 02-17-2013, 04:05 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Here is what I did,
http://www.jeepforum.com/forum/f12/m...95-yj-1397157/
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #21 of 21 Old 02-18-2013, 05:35 AM
ggarland
laybackman - I thought about that, but the hard doors will hit them. My problem is compounded by the fact that I received the wrong drivers side arm so I thought cutting as you did would solve my problem until I held them in place and opened the door. I am looking for an arm that is correct. I received two arms just alike and neither of them fit either side correctly. With some bending and twisting I made the right side work, but there doesn't seem to be any hope for the left.
ggarland is offline
