Mounting a bumper! - JeepForum.com
post #1 of 7 Old 08-18-2011, 09:14 PM Thread Starter
Vin91
Mounting a bumper!
Ok so i have built a front an rear bumper for my beast an i am trying to figure out what the best way to attach my bumpers to my frame??? What would be the best way to do this??
Vin91 is offline
post #2 of 7 Old 08-18-2011, 09:37 PM
hrt4me
pics of your bumpers?
I would suggest you just weld them to the frame...
hrt4me is offline
post #3 of 7 Old 08-18-2011, 09:41 PM
Sovereign08
you really shouldn't mount your bumper if its not consensual. Everything after that would just be awkward.
Lost Dog. Info on Facebook, search Bring Ty Home. Spread the word. $5000 reward, lots of parts for your Jeep =]
http://www.facebook.com/BringTyHome
Sovereign08 is offline
post #4 of 7 Old 08-19-2011, 06:54 AM Thread Starter
Vin91
Can't Put pics from my phone sry... I will when i get home, but i still need some ideas?? I have a rear tire carriers and a stinger on will have a winch as well so i need to come up with something that is going to take a beating.. Anyone got pics of there own bumper builds and how they mounted there's??
Vin91 is offline
post #5 of 7 Old 08-19-2011, 06:59 AM
VACJ5
post pics of your bumpers when you get a chance... but it sounds like you just need some frame tie ins.
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it... 3/4 Ton YJ
91 2 door Cherocar... in progress
BeachMetalWorks Custom CNC cut Jeep parts & more
VACJ5 is offline
post #6 of 7 Old 08-19-2011, 07:12 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
I bought these for attaching my rear bumper:
http://shop.jeeptubes.com/product.sc...&categoryId=10
I made stand-offs out of short pieces of 2"X4" tube steel to go between my bumper and the mounting tabs. I welded those to the mounting tabs then bolted the plates to the frame, then I centered up my bumper on the Jeep, clamped it and tack welded it, then took it off to finish weld it.
Here is my rear bumper thread:
http://www.jeepforum.com/forum/f12/m...-build-845584/
I didn't take any pictures of the process but you may get a better idea of how I did it by looking at the pictures.
I attached my front bumper by cutting up the stock front bumper to make mounting tabs from it. Since it bolts on differently then the rear you don't have to make stand-offs. Just weld them straight to the bumper. Or use your imagination and come up with your own way of doing it.
Post pics if you can...
johnboy68 is offline
post #7 of 7 Old 08-19-2011, 09:58 AM
timatoe
timatoe's Avatar
Make sure you get some frame tie ins for the rear, that thin crossmember back there isn't gonna be happy for long with a bumper and carrier and spare bouncing from it. As for mounting the rear, I took a piece of 2x4x3/16 and cut it in half lengthwise on the 4" side leaving basically two 2x2 c channels. I welded nuts on the inside of the channel and then welded the open side to the bumper and bolted it on from the front side of the crossmember going back.
The front, I made some tabs that welded flush with the top of the bumper and then on the bottom of the bumper (because I used 2x4). The tabs I made were similar to these.... http://troutindustries.easycgi.com/TIndustries/pc/viewPrd.asp?idproduct=7&idcategory=3
I don't have any pictures right now, but could get some later if it would help.
timatoe is offline
A to Z Fab front bumper mounting kit 77 renegade TJ Wrangler Technical Forum 6 10-13-2014 07:36 PM
ARB front bumper mounting.... Mywrangler94 YJ Wrangler Technical Forum 3 01-12-2011 11:03 AM
TJ -vs- CJ (Rear bumper mounting) victoro TJ Wrangler Technical Forum 6 02-07-2010 08:14 PM
Rear bumper mounting gbeltran YJ Wrangler Technical Forum 2 01-19-2008 05:37 PM
bumper mounting bolts nix_toy TJ Wrangler Technical Forum 5 11-07-2005 01:22 PM
