how easy is to blow these suckers? i put a 2100 on and changed the power valve and accelerator pump because it was having issues which google told me would be these two parts. after putting new parts in, drove perfectly. then yesterday morning, got a little pop back through the carb and now i am having original trouble again.
this is actually the second motorcraft i have tried out and i cannot get these things to either run right or last running right. i don;t know why the jeep back fired through the carb, it has not done it before or after but it did. i am tired of screwing with the dang fuel metering system on this jeep and its making me not like having the jeep anymore. i grew up with carbs and had them on hondas, mustangs, vws, and bmws with no trouble but i just cannot get this jeep to run perfectly on one. and when i do, its either short lived or the gas mileage is so incredibly bad that i cannot stand it.
its a 2100, not a 2150. i have slightly larger venturis since the engine is slightly larger then stock. i have 1.14 with 48 jets, which should be acceptable. it ran on a 1.21 but was idling badly from the venturis being a bit to large. the idle would hunt with that big carb.
so, whats ya'lls thoughts on the power valve? is anyone else running a larger size then a 1.08? the 1.21 i got from a guy who was running it on his yj and he said he had no trouble.
hmm, ok. i will have to find some online then. i have 42s, 48s, and 52s
my engine is roughly 275ci so the 1.14 should be pretty close to perfect and i pulled it from a 302 with the jets in it and it ran great with this set up.
timing is 9 or 10 degrees, i can't remember which.
it just aggravates me to continually have to adjust a carb or mess with it. once i got the carbs on the other vehicles set right, i never messed with them again but on this jeep, every carb has needed continuous adjustments, even the great running holley that was on it recently (only removed because the idle mixture screw broke off)
Go w/ the 52s then. I found my 1.08 off local Craigslist.....but the 1.14 should be fine on your rig.
Once you get it dialed, it should be a rock-steady carb.
Make sure you've got a steady acc pump shot coming out of both jets when you open the throttle...they can get plugged. I'd start w/ the rod in the 3rd hole on the throttle shaft arm and inner hole on the pump arm. You can get a carb backfire w/ too little pump input, too.
I'll swap them tomorrow morning then, I just parked at work. I get a good solid twin stream at the accelerator pump squirters. When the carb first was put on, I got a puny thin stream and hesitation so I sprayed them a few times bit ended up having to run a thin piece of metal down the things to get them cleared properly. Even though I took the whole Carb apart and sprayed it all out, I think I should have put it in the dip for a night or two. Seems like little pieces of something are getting into it a lot more then any other carb I have ever had.
From what I've seen, it's in the ballpark of 1/4-3/8 down from the top edge of carb body w/ the needle just seated. I think mine was 5/16 or so. If you have a year, or carb # you can search the mustang forums or Pony Carbs & find your spec. Because they are so basic, float level makes a big deal.
It's off a 65 mustang 289. I have the tag on the carb still so I ran the numbers. I hadn't gotten to switch the jets yet so today is the day to do everything
Float level for a C5ZF-B should be (according to vintage mustang forums): "for your carburetor it should be 15/32 +/- 1/64 measured 1/8 from the float end." A C5ZF-A will be very similar.
Most rebuild write-ups say 7/16" at end of float to top edge of carb body. That's what I set mine at. They also say the MC carbs like 4-5 PSI of fuel pressure, but I didn't bother to put a guage on mine.
I tried a 1.21 on my 4.7 stroker I had a off idle bog I could not tune out. I dropped a 1.08 in there and it runs near perfect. I have not changed a power valve or pump in 4 years.
A backfire will kill a power valve you probably need to look into that.
Wow, I'd have thought a 4.7 stroker w/ the 4.0 head would flow enough air to be fine w/ a 1.21 version.
I pulled plugs today to do the poor man's check for air/fuel ratio.....& they still look pretty light for 2 weeks worth of driving. Mileage is much improved, but I could probably gain some HP by moving up to 48/49 jets.
I got my intake off and carb off. I didn't realize how different the offy was in the mounting bolt area so I had to spend today making the intake bolt on versus actually swapping carbs and power valves & jets. Hopefully tomorrow I can tell y'all about how much better it runs.
That check valve deal goes on the lower plate area but the 2100 isn't listed on the carbs to use it on. Not saying it can't but I will have to find one of those kits and try out a spare 2100 before I do this one
ok, got the intake swapped and everything bolted up. the power valve was good so i put everything back together. i didn;t swap the jets yet because i wanted to try the jeep out with not vacuum leaks or anything to mess with how it ran. it runs super smooth and idles perfectly. i have no more bog or hesitation and it runs up as fast as i want to go with no trouble. i got the auto trans shift linkage to bolt to the offenhauser but ther is zer oway the linkage from the carb will work so i have the trans shift linakge set at a certain point using a bolt and nut and it works. i have to play with it because its shifting higher then i like but it shifts fine so once i get that set, it will work until i get the lokar deal.
i have seen a fairly large increase in gas mileage with this carb. normally i get 100 miles at the half mark when i file the jeep up and drive. right now, i am at 120 and still not to half. thats great because that 10 miles per gallon really sucked.
well i was messing around i removed a bunch of wires in the engine bay. looks a lot better.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
