motorcraft carb swap help - JeepForum.com
post #1 of 6 Old 04-03-2010, 08:19 AM Thread Starter
Timmy69
i got everything that the other threads told me to get to do the swap i put on the adapters and gaskets but the carb just sits on top of the bolts from the manifold and wont go down am i supposed to cut the studs down a little bit but i dont know becaus ei never heard of anyone running into this problem someone please help
It's not what you buy, it's what you build and what you do with it
Timmy69 is offline
post #2 of 6 Old 04-03-2010, 08:26 AM
monkeyhouse
I don't know about the motorcraft, but for my weber conversion, I had to get different length studs and replace the existing ones. I had to use two nuts together on the stud to pull it out. It was alot easier that way.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #3 of 6 Old 04-03-2010, 08:53 AM
jeep108
Can you take a pic and post it? if i remember right my adapter plate mounted to the manifold using allen head bolts that set down in recessed areas on the plate so that everything was flush.
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
post #4 of 6 Old 04-03-2010, 08:55 AM Thread Starter
Timmy69
i figured it out thanks guys
Timmy69 is offline
post #5 of 6 Old 04-03-2010, 09:03 AM
jeep108
good deal - good luck w/ the rest & Don't forget to do the nutter
jeep108 is offline
post #6 of 6 Old 04-03-2010, 09:11 AM
monkeyhouse
Hey, so what was the problem?
motorcraft carb swap! beachedjeepyj YJ Wrangler Technical Forum 102 03-12-2013 03:05 AM
Motorcraft carb swap YJMonster YJ Wrangler Technical Forum 4 03-17-2010 09:13 PM
Dash Guage ?'s after Motorcraft Carb Swap The Buck YJ Wrangler Technical Forum 3 05-21-2006 11:16 PM
Motorcraft Carb Swap done Armytoad YJ Wrangler Technical Forum 6 05-14-2006 09:55 AM
Motorcraft carb swap Armytoad YJ Wrangler Technical Forum 4 04-24-2006 07:56 AM
