-   -   motorcraft carb swap help (http://www.jeepforum.com/forum/f12/motorcraft-carb-swap-help-1005050/)
Timmy69 04-03-2010 08:19 AM
i got everything that the other threads told me to get to do the swap i put on the adapters and gaskets but the carb just sits on top of the bolts from the manifold and wont go down am i supposed to cut the studs down a little bit but i dont know becaus ei never heard of anyone running into this problem someone please help
monkeyhouse 04-03-2010 08:26 AM
I don't know about the motorcraft, but for my weber conversion, I had to get different length studs and replace the existing ones. I had to use two nuts together on the stud to pull it out. It was alot easier that way.:tea:
jeep108 04-03-2010 08:53 AM
Can you take a pic and post it? if i remember right my adapter plate mounted to the manifold using allen head bolts that set down in recessed areas on the plate so that everything was flush.
Timmy69 04-03-2010 08:55 AM
i figured it out thanks guys
jeep108 04-03-2010 09:03 AM
good deal - good luck w/ the rest & Don't forget to do the nutter
monkeyhouse 04-03-2010 09:11 AM
Hey, so what was the problem?
The time now is 09:41 AM.
