Motorcraft Carb Swap done - JeepForum.com
post #1 of 7 Old 05-13-2006, 01:26 PM Thread Starter
Armytoad
I did the nutter bypass and just need to fine tune and finish taking various tubes and vac switches out. What other fine tunig hints are there out there? Do I really need to do the nutter bypass?
It just seems to be smoking a little as well as idling fine and then just dies. What do I need to do?
Armytoad is offline
post #2 of 7 Old 05-13-2006, 02:35 PM
pyro9862
When it dies does it choke and die, shut right off, how about starting it again?
Is the choke functioning properly?
Did you set the mixture?
Did you rebuild the carb? If you didn't perhaps it needs a rebuild. If you did are you sure you put it together correctly?
Perhaps the timeing needs to be ajusted.
Maybie you do need to disable the ECM, I don't think mine is disabled but I think it's the cause of a couple problems I'm having.
pyro9862 is offline
post #3 of 7 Old 05-13-2006, 09:37 PM Thread Starter
Armytoad
It goes to a real low idle then dies. The carb is rebuilt (Got it from the guy on ebay so it should be). It seems to run ok with some sputter at high rpm then if I let off gas it just dies.
I have it hooked to a vacuum gauge to adjust the fuel mixture screws. Is there a better way?
Having a hard time seeing the exact timing marks so I am kind of timing by Vac gauge/sound.
The choke seems to be working fine. Closed when cold then opens all the way when it warms up.
I am thinking it goes back to a timing issue. I am also thinking of redoing the wiring an NOT doing the nutter bypass. I have heard both ways are fine but still unsure about it.
Wife wants to drive it and I am losing my patience.
Armytoad is offline
post #4 of 7 Old 05-13-2006, 09:41 PM
lah2420
Mark your timing marks with a little white or yellow paint. They show up like lights under the timing light.
lah2420 is offline
post #5 of 7 Old 05-13-2006, 09:47 PM Thread Starter
Armytoad
Yeah I am just having a hard time seeing the top of the tab to see what mark is what number. I think there is an old mark but not sure.
Armytoad is offline
post #6 of 7 Old 05-14-2006, 12:46 AM
pyro9862
If you got the whole $250 setup from the guy on eBay ask him. He seems to know a lot about these carbs and can probably give you some insite. That's what you paid the extra money for isn't it? Ther service of having the carb rebuilt, all the parts put in one box, and help with the installation.
pyro9862 is offline
post #7 of 7 Old 05-14-2006, 10:55 AM
Yule16MET
Yule16MET's Avatar
ive said it before! Ask the guy! he is sooooo helpful its creepy. he will even install it for free if your near him
I dream of the jeep, drive the chevy and roush pays for it all
1990 YJ lerado,Soa,2.5R.E.springs,8.8,4.88'sPSC trail cage&rocker nockers w/sliderbars,home made bumpers, 35"boggers,sye, tomwoodsds, revolvers, red & yellow optima, bushwackers,corbeua ss seats,mc2100,juicebox, 3core rad., b&mshifter and highlift,5point harnesses,wheel spacers,9000lb mile marker,ssdash kit,no sway bar, no trackbar, walmart lights,clinometer, XJ passenger shaft, axle tube seals, M.O.R.E track bar
And a Monster Yellow CJ5
40x17's 12"lift full cage
Blackjeepclub #16
Armyjeepclub #16-#1
yellowjeepclub #BIG16
Yule16MET is offline
motorcraft carb swap! beachedjeepyj YJ Wrangler Technical Forum 102 03-12-2013 04:05 AM
weber or motorcraft carb windsoreight YJ Wrangler Technical Forum 9 11-23-2009 08:39 AM
Need help with a Motorcraft carb on my 4.2L learfxr YJ Wrangler Technical Forum 4 07-29-2008 10:59 AM
Dash Guage ?'s after Motorcraft Carb Swap The Buck YJ Wrangler Technical Forum 3 05-22-2006 12:16 AM
Motorcraft carb swap Armytoad YJ Wrangler Technical Forum 4 04-24-2006 08:56 AM
