Motorcraft carb swap - JeepForum.com
post #1 of 5 Old 03-15-2010, 04:37 PM Thread Starter
YJMonster
Im looking to upgrade to a motorcraft 2100 or 2150 carb,
was wondering if one is better than the other, i live in California so
i neeed to smog it. i was thinking of converting to manual choke if i do this upgrade
and im looking for any info on how it works. also wondering of which air filter i would need to fit on the carb, and i would also like to know what ways there is to either fabricate the throttle linkage or replace the throttle cable with one thaat works.
thanks ahead of time for the feedback,
2000 xj 4.5 Rubicon Express extreme duty(sold)
1988 yj 2.5 RC lift, 1/2 boom shackles- My baby
YJMonster is offline
post #2 of 5 Old 03-15-2010, 09:37 PM Thread Starter
YJMonster
10characters
post #3 of 5 Old 03-16-2010, 04:10 AM
wendell
1987 YJ Wrangler
There's a guy on ebay that sells rebult MC carbs just for jeeps. He also has an emssions version. They will hook up to yout throttle cable, there a direct bolt on. He can also do a manual choke version, he can build them the way you want and the carbs are totally rebuilt with all new parts.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #4 of 5 Old 03-17-2010, 09:40 PM Thread Starter
YJMonster
was also wondering if i need to do the nutter before i change carbs
post #5 of 5 Old 03-17-2010, 10:13 PM
beachedjeepyj
Yes you'll need to nutter, and i recommend doing this swap yourself and save about 200$ from the ebay rip off.
Check my sig for a link to my install that has all the part numbers for the adapter plate and air filter, even the jets and rebuild kit.
The 2150 is the one you want if you want to run the smog stuff as it has more vacuum line ports.
Originally Posted by Jeep89JV View Post
Do I let others drive my rig? No -- Why, because if this ship sinks i'll be the captain and I go down with this ship.
beachedjeepyj is offline
motorcraft carb swap! beachedjeepyj YJ Wrangler Technical Forum 102 03-12-2013 04:05 AM
Need help with a Motorcraft carb on my 4.2L learfxr YJ Wrangler Technical Forum 4 07-29-2008 10:59 AM
Dash Guage ?'s after Motorcraft Carb Swap The Buck YJ Wrangler Technical Forum 3 05-22-2006 12:16 AM
Motorcraft Carb Swap done Armytoad YJ Wrangler Technical Forum 6 05-14-2006 10:55 AM
Motorcraft carb swap Armytoad YJ Wrangler Technical Forum 4 04-24-2006 08:56 AM
