motorcraft 2100 swap - JeepForum.com
post #1 of 5 Old 09-08-2005, 12:59 PM Thread Starter
whyjay
I've looked at quadratec for a new carburetor & they have about 6 different one youy can get. Which one will work on a IL6 - 258 ?
Motorcraft 2100 (2-460), (2-464), (ele\c2-465), ele\c2-462) ,(comp\ valve2-902)or the(comp\valve 2-919).
Please help me I need a carburetor bad & I 'm so confused.
whyjay is offline
post #2 of 5 Old 09-08-2005, 03:17 PM
Varnish
Varnish's Avatar
Based on this writeup, I'm using one with a 1.08 venturi, seems to work fine.
http://www.cjoffroad.com/writeup.asp?WU_ID=16&noAdd=1
Motorcraft 2100 Carburetor – Sources: AMC 304 or Ford 302. Unfortunately Motorcraft does not stamp 2100 anywhere I can see on these carbs. The correct size will have “1.08” in a small circle cast on the drivers side of the carb body, somewhat obscured by the accelerator pump linkage. As difficult as this is to measure in the junkyard, the 1.08 is the size of the venturis (the barrels). I have been advised that #108 is 450 cfm, #114 520 cfm, and #121 575. Use the 1.08. This carburetor body is cast from two pieces, a top cover and a combination baseplate / venturi / float bowl. Apparently you can set / observe the float height by idling the motor with the top cover removed. The top cover has the word “Motorcraft” cast into it on the passenger side above the float bowl.
I'd highly recommend considering a used 2100 + rebuild kit which should be far cheaper than $250 that quadratec wants. I got a late 60s one off ebay for $35 + an $15 rebuild kit. After every adapter/hose was bought I had about $125 into it. My first rebuild ever and it was a piece of cake.
'06 LJ, '88 YJ
Varnish is offline
post #3 of 5 Old 09-08-2005, 06:15 PM
beaver24
I was going to do this swap too. I have a 2150 brand new, but I was wondering if it was worth the trouble. Is the improvement substantial, also did you have to re-jet it as I have read most people do. It seems fairly easy of a project I'm just on the fence about it.
89 YJ 4.0 Conversion 99 XJ, 2in BDS, 1" Schackle,31 x 10.5 tires, Herc'ed
beaver24 is offline
post #4 of 5 Old 09-08-2005, 10:48 PM
Varnish
Varnish's Avatar
I thought it was well worth it to eliminate all the spaghetti mess of vacuum hoses associated with the old air cleaner/carb. I was having that carter idle jet clog problem every few months as well which started me looking for an alternative. I'd do it again just because my engine is so simple now.
'06 LJ, '88 YJ
Varnish is offline
post #5 of 5 Old 09-09-2005, 05:21 AM Thread Starter
whyjay
I hear you on that idle jet clogging problem . That's what has me ready to pay $250 to get it fixed. If I can go with the rebuild I 'll give it a try to save $150. As far as the vacuum line go the guy who owned it before me took care of a lot of them.
Thanks for the write up about identifying what I need. That should be a big help.
whyjay is offline
Help with Motorcraft 2100 1989sahara YJ Wrangler Technical Forum 17 09-21-2009 01:24 PM
Motorcraft 2100 jschroder YJ Wrangler Technical Forum 7 06-16-2008 09:10 PM
is this autolite 2100 the same as a motorcraft 2100? rolledthatho YJ Wrangler Technical Forum 2 05-24-2006 08:45 AM
Motorcraft 2100 wglwrm1 YJ Wrangler Technical Forum 2 03-29-2006 11:28 AM
Motorcraft 2100 help wm69 YJ Wrangler Technical Forum 0 11-29-2004 07:25 PM
