Motorcraft 2100 Carburetor Electric Choke - JeepForum.com
post #1 of 10 Old 03-12-2010, 02:15 PM Thread Starter
pkearney06
I have a 1989 Jeep Wrangler YJ with a 4.2l inline 6. The carb has been replaced with a 2100 Motorcraft which has a manual choke. I'm looking to switch it to an electric choke but can't seem to find a kit or all the parts I need anywhere. Called Napa, Autozone, Advanced Auto and JCWhitney. Can anyone suggest a site or a store?
Thanks in advance, all.
pkearney06 is offline
post #2 of 10 Old 03-12-2010, 03:14 PM
beachedjeepyj
Not a suggestion for site but you will need the carter carb electric choke to make it work, then you have to flip the bi-metal coil in the carter choke to make it work with the motor craft.
Originally Posted by Jeep89JV View Post
Do I let others drive my rig? No -- Why, because if this ship sinks i'll be the captain and I go down with this ship.
beachedjeepyj is offline
post #3 of 10 Old 03-12-2010, 07:13 PM
4.7stroker
If you look in the help section they usualy have the choke heater, most auto parts stores carry it.
One of these should work for you.
AutoZone.com | Choke Accessories
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #4 of 10 Old 03-12-2010, 07:36 PM
Alabamaranger
Not sure if it was Autozone or Oreilly's but they had a aftermarket Holly choke replacement that would fit.
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch.
Alabamaranger is offline
post #5 of 10 Old 03-12-2010, 08:46 PM Thread Starter
pkearney06
Thanks guys, for the suggestions. Beachedjeep yj, does the carter carb have the entire kit for conversion or would I need to go piecing together materials?
post #6 of 10 Old 03-12-2010, 11:11 PM
beachedjeepyj
The motor craft and carter share the same choke housing so its fairly easy, all you need is the thermostat choke, and the retainer which is a metal ring with three screws.
AutoZone.com | Thermostat Cap Retainer Kit
AutoZone.com | | Choke Thermostat | CHOKE THERMOSTAT
post #7 of 10 Old 03-12-2010, 11:27 PM Thread Starter
pkearney06
Perfect, thanks alot guys. Really appreciate the help. I'll let you know how I fair with it. Thanks again.
post #8 of 10 Old 03-17-2010, 05:09 AM Thread Starter
pkearney06
Hey, guys, sorry for the bump, I'm having an issue with the thermostat...The good fellas at Advance Auto Parts said this is all I would need Choke Thermostat by GP Sorensen - Part 779-1525 - Advance Auto Parts to convert my 2100 carb to electric choke...was he full of it? Thanks again...
post #9 of 10 Old 03-17-2010, 01:09 PM
Alabamaranger
Post a close up picture of what you have now on the choke side.
post #10 of 10 Old 03-17-2010, 01:55 PM
beachedjeepyj
That just looks like the pricier version of the thermostat, they have one at auto zone for 20$ P# E6079
Can I convert a weber 32/36 electric choke to manual choke? jake42 YJ Wrangler Technical Forum 2 07-19-2011 05:14 PM
Weber Electric choke to Manual Choke? smitkev2 YJ Wrangler Technical Forum 7 10-03-2009 08:12 AM
Motorcraft 2100 carb Qustion HELP CHOKE bcameron1974 YJ Wrangler Technical Forum 2 06-26-2009 04:03 PM
Electric Choke Problem 2100 Jimmycxc YJ Wrangler Technical Forum 3 03-22-2009 03:01 PM
is this autolite 2100 the same as a motorcraft 2100? rolledthatho YJ Wrangler Technical Forum 2 05-24-2006 08:45 AM
