Motorcraft 2100 - JeepForum.com
post #1 of 8 Old 06-14-2008, 08:36 PM Thread Starter
jschroder
Motorcraft 2100
Anybody with this carb running a fuel pressure regulator?
88 YJ with a few junkyard parts.
jschroder is offline
post #2 of 8 Old 06-14-2008, 08:45 PM
yjcrawlr
I don't run one, I run a 3-5gpm external electric fuel pump with a return fuel line to the fuel cell. Works better than any carb I have run.
yjcrawlr is offline
post #3 of 8 Old 06-14-2008, 11:04 PM
4.7stroker
Not here, I kept the return system and everything is great.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #4 of 8 Old 06-15-2008, 11:03 AM Thread Starter
jschroder
I'm curious because after my install if I slowly accelerate it is just fine but if I hammer it, it hesitates for a second. It's almost like it's getting too much fuel and flooding. I've tried changing the timing to see if that helps and also adjusted the jets but it keeps doing the same thing. My next step is to try a regulator unless somebody else has had this same issue.
post #5 of 8 Old 06-15-2008, 02:49 PM
4.7stroker
I woult lean towards adjusting the accelerator pump.
The hesitation could be from not enough fuel to too much fuel from the pump.
Change it from where it is now to a slower fuel delivery to see if that helps.
If not go the other way.
Dwayne
[url]
[url]
post #6 of 8 Old 06-15-2008, 03:58 PM Thread Starter
jschroder
Thanks! I'll try that next.
post #7 of 8 Old 06-16-2008, 09:14 PM Thread Starter
jschroder
No adjustment seems to make a difference. I'm wondering now if maybe the jets that were put in are too big because it's acting like it's flooding until I get about 1/2 way into the throttle after each shift.
I will say that I never knew that 4.2 was so powerful until I got rid of that Carter, put on the Motorcraft and nuttered it. What a difference!
post #8 of 8 Old 06-16-2008, 10:10 PM
4.7stroker
I am running #47 jets here @5500'
I still think it is a tuning issue and probably not your jets.
You would be rich all of the time if it were the jets.
Is your power valve working?
With the motor off and you open the throttle all the way do you get a stream shooting down each bore?
Is your vac advance advancing as the rpm's increase? It is so easy to chose the wrong source when swapping carbs.
Dwayne
[url]
[url]
is this autolite 2100 the same as a motorcraft 2100? rolledthatho YJ Wrangler Technical Forum 2 05-24-2006 09:45 AM
MotorCraft 2100 Duck Doctor YJ Wrangler Technical Forum 15 04-07-2006 07:43 PM
Motorcraft 2100 wglwrm1 YJ Wrangler Technical Forum 2 03-29-2006 12:28 PM
Motorcraft 2100 - - - Where to get it? Rynxprs YJ Wrangler Technical Forum 8 10-22-2005 11:20 AM
Motorcraft 2100 help wm69 YJ Wrangler Technical Forum 0 11-29-2004 08:25 PM
