Motor Time, 331 stroker (5.0) in 88 yj build - JeepForum.com
post #1 of 23 Old 03-04-2014, 07:56 PM Thread Starter
levergun
1979 CJ5
So it's time. The stars have aligned and my 4.0 is on its last leg. I have a acquired a 90 mustang 5.0 that is far from stock.
Motor specs- 90 5.0 .030 over. , 331 crank, AFR 185cc heads, EFI spyder intake, trick flow roller rockers, bbk headers, crower cam, etc... The list goes on... The car was built, put under 10k on it then just sat for 4 years. Got it on the super cheap and no, I'm not changing my mind.
This is to do document how to do this swap cheap, problems and how to solve them.
Motor being pulled
And that's where I'm at now. Got the parts soaking. Gonna put the engine back together tomorrow hopefully..
And maybe start the wiring nightmare. Got the harness pulled out tonight.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #2 of 23 Old 03-04-2014, 08:01 PM
TSEJEEPERS
Cool will be watching!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 23 Old 03-05-2014, 05:04 AM
ownTer
Will be watching as well. I may have 5.0 motor here really soon as well. Not that my swap will happen soon. Still collecting parts.
ownTer is offline
post #4 of 23 Old 03-05-2014, 05:34 AM
Jeepsr4me
Lots of folks really like those Fox bodies. can not tell if its still any good. I say this to mark and watch the build,
Jeepsr4me is offline
post #5 of 23 Old 03-05-2014, 07:03 AM
superj
my parts collecting is at the install point and has been since last year. this is the year i will put the 302 in too!!
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #6 of 23 Old 03-05-2014, 07:17 PM Thread Starter
levergun
1979 CJ5
The body is in pretty good shape. It's about to go on cl.
Got the heads back on and the rockers adjusted. Sorry but no pics. Hope to get the intake back on tommorrow and start working on the harness this weekend. I have to order my ax15 adapter still.
levergun is offline
post #7 of 23 Old 03-05-2014, 08:49 PM Thread Starter
levergun
1979 CJ5
Just ordered the Novak adapter. I hear rumors it only works with the truck style bellhousing. I'm hopeing it's not true and I can make it work but I guess I'll see.
levergun is offline
post #8 of 23 Old 03-07-2014, 02:04 PM
warthog312
I can't express how happy I am to have seen an uptick in the popularity of the Ford swaps around here! Good for you man! Sub'd.
Click for build thread:
- 302//435//20//8.8
>>>the single greatest investment you can make for your jeep is to buy a good welder, and learn how to use it<<<
warthog312 is offline
post #9 of 23 Old 03-07-2014, 04:34 PM
langwilliams
do you know what cam is in that 331? back when I was into the 5.0's those afr heads were considered the best an most guys went with a mid/upper rpm cam.
langwilliams is offline
post #10 of 23 Old 03-07-2014, 07:22 PM Thread Starter
levergun
1979 CJ5
They are awesome heads. I did find out cylinder 3 had FOD at some point as the valve and seat were replaced other than that the motor is brand new. Bearings are perfect. The crower cam is supposed to be a mid but I guess I'll see. I might change it but want to see first. Car was pretty much undrivable due to blown intake gaskets and timing cover gaskets instantly pouring all the coolant out.
Got the heads back on. Adjusted the valves. Trick flow 1.7 roller rockers.
Intake manifold back on
levergun is offline
post #11 of 23 Old 03-07-2014, 07:26 PM Thread Starter
levergun
1979 CJ5
Fuel rail back on. The injectors spent three days in cleaner.
The motor looks a little better
Tommorow I might start fabbing some motor mounts. And Novak says my adapter might be here.
levergun is offline
post #12 of 23 Old 03-07-2014, 09:24 PM
langwilliams
I don't know how many cams crower made, but I remember 2 or 3 were popular because they kicked up performance quite a bit but had good idle an vac so the computer wasn't tripped up. they'd scream with those 4.10 gears but that was with 26" tall tires!
post #13 of 23 Old 03-08-2014, 06:35 PM Thread Starter
levergun
1979 CJ5
Ya. I cannot wait to get it running. I was told the car ran high 10s but when I got it ram like crap due to the blown gaskets. Pulled the old 4.0 today. Just waiting on Novak so then I can fab my motor mounts.
Old motor out....
levergun is offline
post #14 of 23 Old 03-10-2014, 07:10 PM Thread Starter
levergun
1979 CJ5
So I did what Novak and advanced adapters said was impossible. I mated a t5 stang bellhousing to the Novak adapter. I drilled new holes in the corners, used some Allen head bolts and works perfect. About 2 hours of modifying the bellhousing though.
One issue remaining though, I still have to cut about an inch out of the bellhousing pivot because it is to long. The fork is to close to the clutch as where it is now is full disengaged. My plan is to cut 3/4" out of the pivot shaft then weld it back together. Then take 1/4" out of the boss it's mounted on. Then the clutch fork should work perfect.
levergun is offline
post #15 of 23 Old 03-10-2014, 07:32 PM Thread Starter
levergun
1979 CJ5
This is the novak adapter it beautiful.
bellhousing in the jeep.
The pivot I have to shorten.
And the holes I had to drill. I also had to ream it a little to get clearance for the bolts. Hex head wouldn't work. Allen head worked perfect.
levergun is offline
