Motor shifted in wreck, new motor mount not lining up - Page 2 - JeepForum.com
post #16 of 24 Old 10-05-2013, 09:38 PM Thread Starter
93jeepREDSOX
Ok thats what i figured, yea it just needs to move about an inch, maybe an inch and a half.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #17 of 24 Old 10-05-2013, 09:51 PM
Old4X
1990 CJ7
With only 3 mount points for the entire engine/transmission assy, having one mount secure, one missing, and one loose, any rear movement will pull the assy to the rear and swing the un fastened motor slightly more than the actual amount the assy moves rear. It will move in an arc rather than straight back.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #18 of 24 Old 10-05-2013, 09:53 PM
Old4X
1990 CJ7
I just saw you are in Garner. I bought my comealong at Agri-Supply there about 30 years ago.
Old4X is offline
post #19 of 24 Old 10-05-2013, 10:30 PM Thread Starter
93jeepREDSOX
Yea and they are closed tomorrow, so i am gonna try it with a ratchet and see what happens, if that doesnt work, then i will have to stop by Agri or walmart during the week. Thinking more about the way you suggest makes a lot of sense, and i could move the engine by hand a little but not enough to line things up. I knew there had to be a way to rotate it a bit to line things up.
The build thread
post #20 of 24 Old 10-06-2013, 09:56 AM Thread Starter
93jeepREDSOX
So i tried the ratchet strap, it was working until it broke, kinda should have expected that. So now its only about half an inch away from lining up. So once i get a come-along kind of winch, i think i can get it into place. I also forgot to remove the fan shroud and the fan was hitting that so i think that is hindering movement a little too.
The build thread
post #21 of 24 Old 10-07-2013, 07:08 AM
HaskiE
HaskiE's Avatar
it broke! damn! let's see some pics of the come-along when you get it
#theneverendingaxe
HaskiE is offline
post #22 of 24 Old 10-07-2013, 11:40 AM Thread Starter
93jeepREDSOX
Well I was using a really small ratchet strap, I may try a larger one and remove the fan shroud before I by one, cause I'm broke, haha.
The build thread
post #23 of 24 Old 10-08-2013, 07:47 AM
vadslram
Originally Posted by HaskiE View Post
awesome, that's good news!
another point to loosen would be the tranny mount on the belly plate - with no ratchet straps or come-along,etc, you'll want to have everything loose so you can move it by hand - maybe disconnect the driveshafts too
If the MM broke then the only thing keeping it from going all the way through the radiator was the tranny mounts. Check them all.
You don't want to ratchet the engine into place! If it doesn't fit on it's own there has got to be a reason and forcing it is just begging for something else to self destruct more sooner than later.
vadslram is offline
post #24 of 24 Old 10-08-2013, 03:19 PM Thread Starter
93jeepREDSOX
That is possible, and I may need a new tranny mount after I get the engine back in place, but everything looked and felt good, no extra movement but it is something I will keep my eye on. Right now I just want to get the motor bolted into place
The build thread
