Motor shifted in wreck, new motor mount not lining up - JeepForum.com
post #1 of 24 Old 10-05-2013, 11:54 AM Thread Starter
93jeepREDSOX
So i wrecked the jeep, broke the passenger side motor mount, when the engine shifted towards the front a bit. Got the drivers side mount in and now i cant get the passenger side to line up, the engine is shifted forward about 2 inches so the mount wont line up. Any tips, i am working by myself with limited tools.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #2 of 24 Old 10-05-2013, 12:04 PM
BlueRubiconrich
try a comealong,winch or portapower to pull or push it back into place.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 24 Old 10-05-2013, 12:06 PM
johnny27030
How bad was the wreck? Could be your frame rails have shifted....
johnny27030 is offline
post #4 of 24 Old 10-05-2013, 12:08 PM
HaskiE
HaskiE's Avatar
ouch man, sounds like your frame is cranked... I'd try loosening the driverside and pivoting it - maybe get it closer
check the top of your frame behind the shock mounts, there are 3 small drilled holes in either side of the top of each frame rail - are they squished?
#theneverendingaxe
HaskiE is offline
post #5 of 24 Old 10-05-2013, 01:15 PM Thread Starter
93jeepREDSOX
How would you suggest doing that, just wondering, i dont have a winch, just a couple small rachet straps.
The build thread
post #6 of 24 Old 10-05-2013, 01:17 PM Thread Starter
93jeepREDSOX
Frame looks fine, those wholes you are talking about are not squished, all look the same on both sides. What it looks like is when i hit the 18 wheeler the passenger side motor mount gave and the engine shifted forward, thats why the fan blade hit the radiator.
The build thread
post #7 of 24 Old 10-05-2013, 02:35 PM
HaskiE
HaskiE's Avatar
awesome, that's good news!
another point to loosen would be the tranny mount on the belly plate - with no ratchet straps or come-along,etc, you'll want to have everything loose so you can move it by hand - maybe disconnect the driveshafts too
#theneverendingaxe
HaskiE is offline
post #8 of 24 Old 10-05-2013, 03:55 PM
Apollo12227
I love how casually you talk about a Jeep Vs. 18 WHEELER situation. Glad you came out alright! Could have been much worse!
Jeep vs. Semi Truck is a one sided fight to say the least.
Apollo12227 is offline
post #9 of 24 Old 10-05-2013, 04:57 PM Thread Starter
93jeepREDSOX
I did loosen the two middle bolts, but not the third thats closer to the drivers side. How could i move it by rachet strap?
The build thread
post #10 of 24 Old 10-05-2013, 05:35 PM Thread Starter
93jeepREDSOX
Haha yea, and the warn bumper and bull bar really took the brunt of the damage and if i wasnt lifted it would have been really bad.
The build thread
post #11 of 24 Old 10-05-2013, 05:49 PM
Old4X
1990 CJ7
You can get a cheap come-a-long for about 15 bucks at walmart, tractor supply, harbor freight,etc. Will be worth a few bucks ofer fighting a stretchy ratchet strap.
Wrap a chain, rope, etc around the transfer vase and pull toward the rear spring mount on drivers side. Tranny mount MUST be loose (floppy loose) for this to work
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #12 of 24 Old 10-05-2013, 06:44 PM Thread Starter
93jeepREDSOX
For the tranny mount, is that all 3 bolts?
I will try that in the morning
The build thread
post #13 of 24 Old 10-05-2013, 08:00 PM
Old4X
1990 CJ7
You want to ge able to wiggle the rear of the transfer case. The mount bolts go through slotted holes. You will be able to push up on the output shaft housing and move it slightly side to side if loose enough.
Old4X is offline
post #14 of 24 Old 10-05-2013, 08:08 PM Thread Starter
93jeepREDSOX
thanks for the tips, will definitely try this in the morning, should the rear drive shaft be removed?
The build thread
post #15 of 24 Old 10-05-2013, 08:25 PM
Old4X
1990 CJ7
You should not be moving it that far. If the DS is holding the transfer case off and keeping it from moving less than an inch (should be plenty to swing the engine back into place), something else is pranged.
Old4X is offline
