Quantcast Motor mounts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Motor mounts
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 05-12-2009, 12:55 PM   #1
91jeep4sb
Motor mounts
How can you tell when your mounts are going bad. I hear a slight clunk noise whenever i take off. sounds like its coming from the front. I'm not certain but i don't think its suspension related.
91 yj, 4.0 auto
91jeep4sb is offline   Reply With Quote
Old 05-12-2009, 01:17 PM   #2
mikebigh
mikebigh's Avatar
1987 YJ Wrangler
put a jack under the motor(with a piece of wood to cushion), see if it moves alot. Also look for dry rot, cracks etc etc. Usually when there bad, they will sit all the way to one side(front or rear) cause the rubber wears out.
Check all of your drive shaft ujoints.
Rock Krawler Suspensions
mikebigh is offline   Reply With Quote
Old 05-12-2009, 01:23 PM   #3
Louie4
Injanir
Louie4's Avatar
If you have the auto (I see you do). Get a buddy or someone to crank the jeep and shift from Drive to Reverse. You'll see the motor mount jump if it has come apart. But for the most part they are easy to tell when they are bad. The metal sleeve usually has separated from the rubber.
Lou
Vote January YJ of the Month! (click here)
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote
Old 05-12-2009, 01:26 PM   #4
Randy77358
and they are easy to change
Randy77358 is offline   Reply With Quote
Old 05-12-2009, 02:39 PM   #5
mikebigh
mikebigh's Avatar
1987 YJ Wrangler
Yep, 3 bolts..1 from the top, 1 from the bottom, the long one through the middle that holds em to the engine brackets. Do em one at a time, with a jack under the motor.
Old 05-12-2009, 03:00 PM   #6
blue1989yj
http://www.jeepforum.com/forum/f12/jeeps-shaking-too-much-when-stoped-light-763708/
This was up here a few weeks ago.
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline   Reply With Quote
Old 05-12-2009, 03:03 PM   #7
trucknut
when they look like this
dont forget to loosen your transmission mount so you dont damage it.. or at least thats how it was with the 2.5l
1994 Jeep YJ 2.5
My Save the YJ from the junkyard project...
http://www.jeepforum.com/forum/f12/my-94-rebuild-thread-747404/
2001 Toyota Tundra TRD
trucknut is offline   Reply With Quote
Old 05-12-2009, 07:35 PM   #8
Tshark299
1987 YJ Wrangler
When mine went, my shifter would flop around alot when taking off and hitting potholes... the whole drivetrain was rocking back and forth
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parting the rest out
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline   Reply With Quote
Old 05-13-2009, 01:14 AM   #9
91jeep4sb
Thanks guys.. those pictures were especially helpful.
Glock Forum
