Quantcast Motor mount swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Motor mount swap
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 08-10-2009, 09:31 AM   #1
chico166
2011 JK Wrangler
Motor mount swap
I'm trying to save a little cash here by thinking about swaping out the poly motor mounts for the rubber ones that I just ordered from browndog and doing it myself. I am a novice to things like this with limited tools, so my question is should I pay someone $50 to put them in or is this something I can do if I take my time? It's not a daily driver and the sense of accomplishment would be great if I could do it myself, I just don't know what all tools I would need and if I would be in over my head. Thanks.
"Just because you are UNIQUE doesn't mean you are USEFUL"
chico166 is offline   Reply With Quote
Old 08-10-2009, 09:35 AM   #2
idaholtby
Do it yourself, pretty easy job. Just support the engine with a block off wood under the oil pan with a jack and do one side at a time. I see you have the 2.5L, so I hope you got the cradle for the passenger side mount from Brown Dog as well. Be sure to use loctite on the threads!
idaholtby is offline   Reply With Quote
Old 08-10-2009, 09:55 AM   #3
Mean Max
Mean Max's Avatar
I agree with idaholtby, do it yourself. I haven't done mounts in a 4 cylinder, but I've done many 6 cylinder mounts.
I usually start with the passenger side, and I do one side at a time, and I start by just loosening the large "main bolt" that runs through the motor mount and then leaving it in place, then I remove the bolt & nut that attach the motor mount to the frame, next I use a jack & block of wood on the oil pan and just take the weight off of the mount. Lastly I remove all the bolts that attach the engine mount bracket to the engine block & pull the bracket & mount out as 1 piece & swap the mount on the bench.
When I reinstall the first new mount, the only bolts I tighten are the bolts that secure the bracket to the engine. The remaining bolts are left loose after getting the threads started. This allows the engine to flex around a bit more while doing the second mount.
Make sure to DOUBLE-CHECK all bolts to make sure they're tight when done!
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 08-10-2009, 10:13 AM   #4
RockWoRM
don't fear the Jeeper
RockWoRM's Avatar
I did my own, also. It was'nt 'hard', but it was no 'cake walk' either. Had to have a buddy help line up the bolts, which was a pita, and do a little 'trimming' since it was a MORE 1" over. I'd do it again, of course, but if you're not that good with tools or don't have any, then IMHO $50 is'nt unreasonable.
WRM
'92 YJ, 4.0, 5sp, 8.8 w/ 4.56's locked F&R, Teralow 4-1, HD SYE, BDS 5" SUA lifted on 35 MTR's. PSE front trail cage kit, 1ton TRE flip, 1"shackles, 1"BL, 1" MM. <><
RockWoRM is offline   Reply With Quote
Old 08-10-2009, 01:42 PM   #5
chico166
2011 JK Wrangler
I'm hoping that since the brackets were just put in 2 1/2 years ago that it shouldn't be that bad to get the bolts out and loose. As far as the passenger side cradle goes, I can't recall if I got that part back then or not. Its was in the shop getting a clutch and slave cylinder when they found the motor mounts rotted so I ordered from BDI and let the garage put those in.
Old 08-10-2009, 01:46 PM   #6
Tom95YJ
It's Only Rock Rash......
Tom95YJ's Avatar
I installed my Brown Dog 1in MML on my YJ last week it took about 45mins with a beer break or Two.
Soon as I get back from my honeymoon I'll finish up my belly up
'98 TJ Built Sold
'95 YJ Built Sold
'99 XJ 3" on 31's Build Thread
Utah Jeep Crew Member #109
Tom95YJ is offline   Reply With Quote
Old 08-11-2009, 11:01 AM   #7
chico166
2011 JK Wrangler
Thanks for the replies. I will let you know how it turns out.
Old 08-11-2009, 12:56 PM   #8
Brown Dog
Vendor
Brown Dog's Avatar
If it were me, I would do it myself. You can call the guy at Brown Dog (me) anytime if you get stuck or need advice.
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Join our FaceBook group
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% MADE IN AMERICA
OFFROAD-REVIEW of Browndog Superkit
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
3.5" Superlift SL
AA SYE
35" BFG Mud Terrains
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline   Reply With Quote
Old 08-12-2009, 08:54 AM   #9
chico166
2011 JK Wrangler
Hey thanks! I was going to post something up about you guys after I got the mounts in but now seems like a good time. I was extremely impressed with ya'lls service! I ordered on-line but I got a phone call shortly thereafter to ask me a few questions and to make sure that what I had ordered and was receiving the correct product for the job. I ended up talking to a guy there in your shop (can't remember the name, Tim maybe) and he gave me some help tips and info on installing these and he offered to help if I got stuck that I could call and he would walk me through it. I have never dealt with a more helpful company or people. I would recommend you to anyone
Old 08-12-2009, 09:14 AM   #10
machinehead131
i ordered the brown dog mounts too. They look good, putting them in today or tomorrow!
Looking for TJ Rear Flares, if anyone has any please PM ME.
Thank you.
machinehead131 is offline   Reply With Quote
Old 08-16-2009, 11:34 AM   #11
chico166
2011 JK Wrangler
I'm a little stuck here putting these in. I started with the passenger side and took the nut off the bolt that passes thru nthe center of the mount, but it doesn't look like it will come out because the alternator is in the way. I have read nothing that mentions removal of the alternator so am I missing something? So far thats the only bolt I have removed.
Old 08-16-2009, 11:42 AM   #12
Brown Dog
Vendor
Brown Dog's Avatar
We have spoken on the phone and solved the problem. But for those of you out there encountering the same problem: The engine bracket to which the motor mount bolts, is held onto the block with either 3 or 4 bolts and/or nuts (3 for a six cylinder, 4 for a four cylinder). Remove all fasteners from the bracket and mount, then take the assembly out as a unit. It is MUCH easier that way. If the length of the through bolt allows, install it in the opposite direction on re-assembly. This will make the process much easier if you need to do other work in the future.
Brown Dog Offroad
91YJ 2.5
2" BL
3.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
Old 08-16-2009, 07:54 PM   #13
Mean Max
Mean Max's Avatar
No kidding?
Maybe that's why I posted
"Lastly I remove all the bolts that attach the engine mount bracket to the engine block & pull the bracket & mount out as 1 piece & swap the mount on the bench."
in my advice to the OP in post #3 of this thread.
The help is available here, you just need to use it.
Kudos to Brown Dog for his tech help to the OP on the phone, that's why I always advocate his products, IMO he's "one of us" type of Jeepers.
Max
Old 08-17-2009, 09:39 AM   #14
chico166
2011 JK Wrangler
Thanks to Brown Dog and Mean Max, I did get the mounts in. Sorry I missed what you were saying about pulling the engine mount bracket from the block Max. Again I haven't had that much experience working on it but when I talked to BD on the phone he said what you mentioned in your reply to my thread and so then it made sense to me what you were saying in your reply. My apologies if it seemed as though I ignored your help Max, but I really appreciate everyone's willingness to help out a novice
P.S. It was great of BD to call me back on a Sunday with advice!
Glock Forum
