Motor mount - JeepForum.com
post #1 of 2 Old 09-17-2001, 11:59 AM Thread Starter
gatt
Motor mount
I just bought a 94 wrangler. I noticed that the driver side motor mount was distorted so I decided to change it. I had no problem removing it but installing the new one was a bit of a challenge. the engine was shifted back on the drivers side, therefore the engine support bracket did not line up with where the engine mount attaches to the frame. In order to get the engine aligned properly I dissembled the plate that supports the transmission and shifted the engine. Once the engine was shifted forward I was able to assemble the new engine mount with no problem. Problem now was that since the engine and transmission were shifted slightly to get the engine mount and engine bracket to line up, the bolts on the rear mount that is attached to the transmission did not line up with the slotted holes in the plate that supports the transmission. This support plate only has slotted holes for adjustment from front to back and not side to side. I decided to slot the holes to the side in order reassemble the support plate. The amount of shift at the rear mount was about 3/4 of an inch towards the driver side. My question is, did I do the correct thing in slotting the holes in the support plate in order to mount the engine/transmission to it? Will shifting the engine/transmission 3/4 of an inch damage anything such as the rear drive shaft or front drive shaft or u-joints?
Any comments or helpful hints will be appreciated.
Thanks
gatt is offline
post #2 of 2 Old 09-17-2001, 07:51 PM
osburn
osburn's Avatar
Some of them can be that way. Especially when the tcase skid gets damaged from heavy trail use. If you're not noticing any vibrations, then ya probably didn't move anything enough to cause any problems.
I'd like to warn anyone with the 4.0, the motor mounts commonly work loose. Get under there and make sure the bolts are tight. Either that, or wait until they shear off in the block. That's way more fun to fix.
Matt Osburn
Score 1032
osburn is offline
Motor Mount Lifts Cause Bad Motor Vibes? dieseldell TJ Wrangler Technical Forum 35 10-26-2011 06:18 AM
Motor mount tower/motor frame mount location pepto YJ Wrangler Technical Forum 11 03-24-2009 02:05 PM
motor mount lift, tranny mount?? dream911tommy YJ Wrangler Technical Forum 0 05-28-2008 07:20 AM
Tranny Mount With a Motor Mount and Body Lift Tommy R TJ Wrangler Technical Forum 2 05-13-2008 08:46 AM
What tranny mount & Motor mount you using? TJSilverSport02 TJ Wrangler Technical Forum 1 08-15-2004 06:56 PM
