MOST but not all dash lights out - JeepForum.com
post #1 of 11 Old 04-05-2010, 06:33 PM Thread Starter
geusey
Well, if you've seen some of my previous posts, you know that I'm not an electrical wiz (which sometimes makes owning a yj a living nightmare), so this is really weirding me out. When I turn on my headlights, the dash lights for the rpm gauge and the temp and oil pressure gauge come on, but thats all the dash lights that come on. Also, the turn signal indicators, brake warning light, and the rest on that top row of warning lights DO NOT come on. The check engine light and everything else on the bottom row of warning lights DO work.
I checked the fuses, and they are all fine (every fuse in that jeep is fine, trust me). I checked the bulbs inside the dash and they all seem fine. I really have no idea what to look for. any clue what this might be?
This is a 92 4.0
It seemed like a good idea at the time...
geusey is offline
post #2 of 11 Old 04-05-2010, 06:51 PM
moonshinefuel
If you are getting power to the switch, then I would think you are fine up to there. The problem would have to be somewhere between the switch and the tachs.
moonshinefuel is offline
post #3 of 11 Old 04-05-2010, 07:10 PM Thread Starter
geusey
Yeah, thats partly what is so aggravating. I know the problem has to be somewhere past the switch, and since some of the lights come on, then I know that power is getting to the gauge clusters. Could the light bulbs be on the same circut? as in, if one goes out, all the ones after it on the circut go out? like christmas lights? its a stretch, i know...
geusey is offline
post #4 of 11 Old 04-05-2010, 08:22 PM
Mark05059
the bulbs get their contact/power from the back of the printed circut ribbon. They sometimes stop making contact and need to be "erased"... meaning take an eraser and erase where the bulb holders touch... and then shine up the holder connections themselves...
See if that helps you "see the light"
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 11 Old 04-05-2010, 08:29 PM Thread Starter
geusey
Ok, i'll give it a shot Thanks!
geusey is offline
post #6 of 11 Old 04-05-2010, 08:48 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Also check the connectors at the bottom of that plastic mount. IIRC, the top gets power from one side and the bottom gets power from the other.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #7 of 11 Old 04-05-2010, 08:56 PM
Sparkfly88
I just recently re did that plastic thing behing the gauge cluster..
The copper "wire" leading to my clock was fried, so I had to put a legit wire in its place.
That wire was keeping all except two lights from turning on.
I used 1000 grit wet/dry paper if i remember right, sanded all the bulb contacts...sanded where the bulb contact the copper on the plastic, and sanded all the contacts that the connector plugs into.
Worked like a charm.
Sparkfly88 is offline
post #8 of 11 Old 04-05-2010, 09:05 PM
bharris68
Daily Driver
Read through here: http://www.jeepforum.com/forum/f12/r...er-how-991307/ let me know if that helps
bharris68 is offline
post #9 of 11 Old 04-05-2010, 10:45 PM Thread Starter
geusey
well, i took it all apart and went through all the connections much more thoroughly.
I cleaned up and polished as much as I could find, and found a couple dead and missing bulbs (how? Where did they go? who would just take them out and not replace them?), and got all the lights on gauge cluster in the center, towards the passenger seat containing the 4wd lights, fuel, oil, temp, and volt gauges working. The problem is now just in the main gauge cluster above the steering wheel. The speedometer is now the only gauge that still doesn't illuminate, and the top row of warning lights do not work.
What I found when inspecting the plastic circuit board was heavy corrosion on the copper in the circuit board leading to the speedometer and upper row of warning lights. Anyone know how to repair something like this? Or where to get a replacement, and how much it might cost?
geusey is offline
post #10 of 11 Old 04-05-2010, 11:04 PM
kbrawlz
yeah, this happened to mine after sitting for 6 months and staying humid inside. i took the ribbons all the way off and scraped the corrosion clean and had to repair a section using copper stuff for soldering stained glass, adhesive on one side. i cut a little section and soldered it on and sealed it. i might be able find you an new one in a wrecking yard and send it to you.
jeep or die
kbrawlz is offline
post #11 of 11 Old 04-05-2010, 11:13 PM Thread Starter
geusey
Yeah, this jeep ended up sitting around for almost a year, including a rainy Oregon winter. I really think the circuit board is shot. I'm considering maybe taking this opportunity to upgrade and put in new speedo and tach gauges that don't use the stock circuit board, but if you can find me a new one and send it, pm me.
geusey is offline
dash lights just went out, along with running lights, and tail lights. what happened bortz1892 TJ Wrangler Technical Forum 50 09-04-2016 05:33 AM
89 YJ Electrical Issues blinkers/ dash lights come on with Brake lights Cajun90YJ YJ Wrangler Technical Forum 9 10-03-2010 05:33 PM
TJ Dash lights, and other interior illum lights not working kells81 TJ Wrangler Technical Forum 2 02-22-2010 09:05 AM
No dash lights, tail lights or parking lamps BlkBird TJ Wrangler Technical Forum 5 01-11-2008 08:03 PM
2000 Wrangler No park Lights or Dash Lights Deb04 TJ Wrangler Technical Forum 2 04-06-2004 10:28 PM
