MORE shackles- how to order? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > MORE shackles- how to order?
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 03-05-2012, 06:00 AM   #1
shoalsjeep
went online to order MORE 5/8 shackles to go with new OME springs. the website lists many other companies springs i.e. pro comp, RC, black diamond etc. but, not OME. How do you know which springs are similar to OME..?
shoalsjeep is offline   Reply With Quote
Unread 03-05-2012, 06:07 AM   #2
yellow2kgt
Give them a call. They will know exactly which bushings you need. I had to do the same when I ordered mine.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.10s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft..
yellow2kgt is offline   Reply With Quote
Unread 03-05-2012, 06:41 AM   #3
shoalsjeep
ok, tried calling quadratic.....same issue. guy on phone wasn't sure which shackle i needed for OME spring....
Unread 03-05-2012, 07:00 AM   #4
bestos
does your OME come with new bushings? i thought the Shackles came with bushings and the bushings were the difference, not the shackle, know what I am syaing?
1995 YJ - 33" BFG KM2 - 4.88 w/ Aussie front locker. 2.5" OME. 5/8" shackle. 1" JKS body.
1991 YJ - 4.0 - Stock and banged up and recent purchase
bestos is offline   Reply With Quote
Unread 03-05-2012, 07:22 AM   #5
shoalsjeep
i did order new bushing kit with springs...still not sure how to order
Unread 03-05-2012, 07:40 AM   #6
jbolty
ISO 9001 Compliant
jbolty's Avatar
I ordered mine direct from MORE when they were having a sale; check the vendor section to see if a deal is currently happening. Or, Northridge4x4 is always good to deal with.
95% sure the spring eye on the shackle end is 1 1/4". Maybe someone with an uninstalled set of springs can do a quick measre.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 03-05-2012, 10:27 AM   #7
imstillatwork
OME springs are 1/8 inch narrower than many others. To make the shackles fit properly there are differences in the bushing shoulder width. Make sure you install the narrow shoulder bushings in the frame eyes (furthest front and furthers rear) and the wide shoulder bushings in the springs (both ends).
imstillatwork is offline   Reply With Quote
Unread 03-05-2012, 12:47 PM   #8
DLWRUBI
My MORE shackles didn't come with frame bushings only the sping and shackle bushings, I had to order the frame pieces seperately.
You should call MORE directly to find the sizing and you can just order them from there as well since QT will have them drop shipped from MORE anyway..
DLWRUBI is offline   Reply With Quote
