MORE shackles - JeepForum.com
post #1 of 9 Old 11-17-2005, 07:45 PM Thread Starter
standnstillfast
MORE shackles
Hey guys, I got the MORE greasable shackles for the front of my jeep and first off the spring hits teh center brace on the passenger side slightly for some reason, what could cause that and secondly I am not satisfied with these MORE products at all first off they sent them shackles out a week late and tonite when I was torquing the bolts they snapped on me. It's driving me nuts.
1989 YJ, 3.5 BDS lift, 2" BL, BDS steering stabilizer, 5/8 MORE shackles, CRT HEI, 35 x 12.5 BFG A/Ts , soft 8's, IPF H4 headlights, Weber K551, dynomax exhaust. Herculined tub, neoprene seat covers, white gauges, JBL speakers, overhead console, and much more
standnstillfast is offline
post #2 of 9 Old 11-17-2005, 07:53 PM
483Fitter
483Fitter's Avatar
umm how tight were you making those?
483Fitter is offline
post #3 of 9 Old 11-17-2005, 08:14 PM
mjeselskis
Yeah no kidding, I got MORE's boomerang shackles and I love em. I only torqued to 30 lbs but I dont know how tight someone would have to go to snap the bolts.
1989 black YJ, 2.5L 5speed
SOA on stock springs with add a leaf in rear, Welded D30, Posi-Locked, traction bar, Rear 5/8" Boomerang Shackles, OBA, Ditched Front and Rear Trac Bar, 34x10.5 LTB TSL Swampers on 15x8 M/T Classics, Ramsey Pro Plus 9000
mjeselskis is offline
post #4 of 9 Old 11-17-2005, 08:38 PM Thread Starter
standnstillfast
the spec in my haynes manual said 55 so i was going to 50 when they snapped
post #5 of 9 Old 11-18-2005, 05:33 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Originally Posted by standnstillfast
...first off the spring hits teh center brace on the passenger side slightly for some reason, what could cause that...
Short answer? They don't fit. Aftermarket spring makers can make the spring eye any diameter they choose, and most all are larger than stock. Aftermarket shackle makers tend to make them for stock springs. If I was in your place, I would alter the offending shackle to fit (e.g. grind down the center brace a bit).
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #6 of 9 Old 11-18-2005, 11:07 AM Thread Starter
standnstillfast
the thing is when I ordered them I specifically ordered them for BDS springs and the dealer said they would fit.
post #7 of 9 Old 11-18-2005, 12:56 PM
Road Head
Arent BDS military wrapped? I think thats why they hit. And are you running them the correct direction. For the fronts, you should be running them in what looks to be an "upside down" configuration. The shorter end of the shackle should be bolted to the frame, the longer end to the spring.
92 YJ, 4.0L, 5-speed, 35" Goodyear MTR's
Road Head is offline
post #8 of 9 Old 11-18-2005, 01:00 PM
atomicmoose
Just call me Moose
atomicmoose's Avatar
No need to go that tight....30-35lbs is perfect.
atomicmoose is offline
post #9 of 9 Old 11-18-2005, 02:28 PM Thread Starter
standnstillfast
"roadhead" they're not the boomerangs for the front, they're the standard lubeable shackles. I was thinking about just pulling the center brace out and going without it, does anyone think that'll greatly affect the shackle?
All about shackles Brandon_YJ YJ Wrangler Technical Forum 98 02-03-2014 08:35 AM
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 01:35 PM
To add shackles or not to add shackles that is the question! 1997_Sport YJ Wrangler Technical Forum 16 09-30-2009 06:39 AM
shackles bignateb YJ Wrangler Technical Forum 13 03-22-2009 12:30 PM
shackles jeepmud YJ Wrangler Technical Forum 3 12-07-2005 02:08 PM
