more flex??? - JeepForum.com
post #1 of 7 Old 10-09-2002, 09:18 PM Thread Starter
themonster
more flex???
how can i get more flex out of my 4" rubicon suspension lift? right now my freinds 2.5" lift can flex out way more than mine can, how can i change this???
themonster is offline
post #2 of 7 Old 10-09-2002, 10:27 PM
V8wrangler_idaho
get greasable shakels put them on loosly. take off your track bar in the back of your jeep and get quick disconnests for your antisway bars. that will help a ton
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline
post #3 of 7 Old 10-10-2002, 07:52 PM
KYgreenYJ
Revolvers and then disconnect ur sway and track bars then you will get alot more flex
Black 2012 JKUR 2.5" Rock Krawler Max Travel suspension with Bilstein 5100's, 35X12.5R15 MTRK's on MB Ultras, Sleeved and gusseted front axle with Synergy balljoints, JCR bumpers F/R
Old Jeep, SOLD:
94 Green YJ SE 4.0L 5spd
3.5" BDS lift, 1"MML/BL, Revolvers, SYE/CV, no track bars or sway bars, MORE sport cage
Green Jeep Club Member #20
KYgreenYJ is offline
post #4 of 7 Old 10-10-2002, 08:24 PM Thread Starter
themonster
i already have my sway bar off and where can i find greasable shackles? could my 35" tires be a restriction on my flex at all? and thanks in advance for all the advice and help
post #5 of 7 Old 10-10-2002, 09:39 PM
tophillrod
tophillrod's Avatar
Your 35's could only help the flex unless you are bottoming out on something. You say you allready took the sway bar off... did you take off the track bars? I have front & rear track bars off and sway bar disco's and when all is said and done I have much more than w/ out the sway bar. There is more to this anyway...from what I have heard from the salesman a RE is that there 4.5 extreeme is there most flexible kit. Does your friend have a kit from someone else that is softer? - does he have everything disconnected? This would be a big factor in finding out your problem. HTH : )
'92 YJ 4.0 HO
2" SL 2" BL 33" BFG AT's (for now)
RE quick disco's
Warn tire rack
Dana44 rear w/ Track lock
4:10 gears
135k and running strong...
tophillrod is offline
post #6 of 7 Old 10-10-2002, 10:15 PM
St.LJustin
St.LJustin's Avatar
Are you running 35" tires with a 4" lift and nothing more? What Kind of shackles are in the rear? Regular ones like the front, or are they boomerangs? I would say if you've disconnected your sway bar and you're still getting poor flex then I'd say something is wrong with the setup. I've got the RE 4.5 Extreme Duty lift and can completely stuff my 33s.
Black 95 4.0 YJ, RE Extreme Duty 4.5" with 33x12.5 BFG MTs and Much Much More
Member #5 of the Black Jeep Club
St.LJustin is offline
post #7 of 7 Old 10-11-2002, 01:10 AM
V8wrangler_idaho
to me it still soinds like the shakels. I would by greasable shackles. also you could by some urathain upper shackel bushings and it would help the flex as well. The stock rubber bushings suck. Also those exstented bump stops that came with the lift that go on your axles under the u bolts take them off. I did that to mine and it helped out on flex too. and i had no problems doing that. You can get greasable shackes from quadratec.com
Daniel Mclay
RE 3.5 - Need more flex?? seabass2020 TJ Wrangler Technical Forum 54 07-16-2009 11:25 AM
Max. Flex vs. Useful Flex and The Anti-rock lupinsea TJ Wrangler Technical Forum 34 10-29-2008 10:03 AM
Need More Flex JamesLouis YJ Wrangler Technical Forum 17 11-08-2006 07:25 PM
flex tjsooley TJ Wrangler Technical Forum 9 03-04-2006 07:10 AM
RE Super flex or Standard flex treypal TJ Wrangler Technical Forum 10 06-21-2005 08:01 PM
