More flex? - Page 2 - JeepForum.com
post #16 of 30 Old 04-20-2010, 12:40 PM Thread Starter
Ronnie-Evans
Ya sorry about the horrible pics! Didnt relize till they were up larger. The springs are actually softer than my buddys (90 wrangler) so im stoked on that. Ill post pics of the bump stops later today. Does it look like i should possibly swap to some better shackles? and how may i find a torque setting for em?
Ronnie-Evans is offline
post #17 of 30 Old 04-21-2010, 06:15 PM Thread Starter
Ronnie-Evans
Here are some pictures of the bump stops that concern me there like this on all four. Maybe im wrong. What to do here guys?
post #18 of 30 Old 04-21-2010, 06:19 PM
YJake
I hear from another thread on here that you can open your doors and get better flex.
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #19 of 30 Old 04-21-2010, 07:12 PM Thread Starter
Ronnie-Evans
I saw that post. Sounds wacko to me
post #20 of 30 Old 04-21-2010, 10:03 PM
clemsonfan16
Jake
Hahahaha its "whats everybodys doin" these days!
clemsonfan16 is offline
post #21 of 30 Old 04-21-2010, 10:08 PM
clemsonfan16
I cut my bump stops off after I put my lift on. Huge difference! But you have the downside of your shocks bottoming out if your not careful. Just "trim" them a little. There is prob 4in of rubber there. Maybe more.
You mean flex like dissss?
post #22 of 30 Old 04-21-2010, 11:21 PM
Axl Jack
Here is a pic of my front axle the day I finished putting on my lift:
As you can see, with only 4" springs there wasn't a whole heck of a lot of room between the rubber bump stops and the bump stop extenders included in the kit. Kind-of defeats the purpose of axle articulation.
Shortly thereafter, I removed those extentions along with the track bar and sway bars (and added 5/8" booms) and the flex is very good for a SUA setup. The shocks don't bottom out, but I would wager a guess that if I were any higher suspension-wise they probably would. (So for more room I added TJ flares and soon hope to add a 1" BL).
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #23 of 30 Old 04-22-2010, 02:14 PM
RockWoRM
RockWoRM's Avatar
Like we've been saying. Disconnect the sway and tracs and flex it out. If you have room for up travel and there's no danger of inverting the springs, then your next step would be to remove the axle bump spacer...not the rubber bump itself. The spacer can be adjusted/cut down to accomodate what you need. Again, you're more than welcome to flex it out here and I'b happy to re-weld the spacers if need be for ya. BUT GET THOSE BARS OFF AND CHECK IT FIRST!
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #24 of 30 Old 04-22-2010, 02:22 PM
monkeyhouse
Originally Posted by RockWoRM View Post
No thread concerning sways or tracs is complete with out this...
For the OP... get yourself a set of sway disco's. IIRC I have the RE's and they work well. (when I use them. hehe.) Don't remove the bumps until you know where your springs will max out. Most likely you won't need to. Depending on what kind of shackles you have... grease them up and re-torque to no more than 50-60 lbs.
If you need to test them out, I have a nice little hill you can borrow.
WRM
Where's the pic of having a beer with them, that was classic!
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #25 of 30 Old 04-22-2010, 02:54 PM Thread Starter
Ronnie-Evans
Thanks Alot. Just got the bars off. Now going out to get the sway off. Where about do you live? I see your from my area?
post #26 of 30 Old 04-22-2010, 05:35 PM Thread Starter
Ronnie-Evans
Got the sway/track bars removed just now...Going out for a test run..Pics to come..Thanks guys!
post #27 of 30 Old 04-22-2010, 08:13 PM
RockWoRM
RockWoRM's Avatar
Ranchos, just off 12. 'bout 10 min. from blackstone/herndon.
RockWoRM is offline
post #28 of 30 Old 04-22-2010, 08:18 PM
RockWoRM
RockWoRM's Avatar
Well, at least you're an eager beaver. no need to pull the whole sway, just the links. oh well, it will be easy to pull off the links if you decide to get disco's.
WRM
RockWoRM is offline
post #29 of 30 Old 04-22-2010, 08:25 PM
dadstoys2
1987 YJ Wrangler
yeah put the sway bar back on and get some disco's
I still need to pull my rear trac bar.
~Rich
87 Wrangler Ford 302
2"bodylift 5"suspension 35" bfg A/Ts
Np435 trans w/ np205
dadstoys2 is offline
post #30 of 30 Old 04-22-2010, 08:45 PM Thread Starter
Ronnie-Evans
Ah man your right down the 99 from me then. We need to get together so i can pick your brain about some stuff and wheel this thing. Thanks again for the help!
Max. Flex vs. Useful Flex and The Anti-rock lupinsea TJ Wrangler Technical Forum 34 10-29-2008 10:03 AM
How far is too far with flex? glockfire TJ Wrangler Technical Forum 5 08-15-2007 10:43 PM
No flex zolon YJ Wrangler Technical Forum 41 08-31-2005 07:24 AM
RE Super flex or Standard flex treypal TJ Wrangler Technical Forum 10 06-21-2005 08:01 PM
flex fan? doorocks TJ Wrangler Technical Forum 6 12-02-2003 04:36 PM
