More electrical gremlins- heater blower - JeepForum.com
post #1 of 11 Old 10-20-2011, 11:33 PM Thread Starter
Xpress
So I noticed tonight while driving, my heater sounds funny. When I get on the gas a bit, it sounds like it's losing RPMs, then once i'm up to speed it returns to a normal RPM. Also, sometimes it feels like i'm losing power and the lights dim.
I had my pair of 100w spots on as well. Could this be an alternator issue? Mine sounds like a grinder, and I know it's probably getting close to time to replace it.
All about that unibody life.
Xpress is offline
post #2 of 11 Old 10-21-2011, 05:49 AM
jsawduste
2006 YJ Wrangler
You answered your own question.
I would suggest taking your alt. to a alternator/starter rebuild shop instead of jumping on a replacement from the parts store. You will end up with a better end product for much less $$. And the rebuild shop will have tested the output in AMPS not just measured voltage.
Might consider some of the alt/battery cable wiring upgrades that have been posted lately also.
jsawduste is offline
post #3 of 11 Old 10-21-2011, 06:04 AM
LeeIndy
^^ this and deffinately replace the ground cable, the cable to the alterntor. the cable to the starter. with GOOD ones.
2012 JKR on 37s (built and beat on)
2002 Grand. new to the family. 4in longarm enroute
LeeIndy is offline
post #4 of 11 Old 10-21-2011, 11:37 AM Thread Starter
Xpress
I keep getting this feeling that the battery cables already aren't stock.. They're pretty big, but then again I'm comparing them to what Toyota uses...
I'm also wanting to run a higher output alternator eventually. Should I just go for one before mine dies, or replace mine with an OEM? Unless a shop can rebuild it in a day or less, I don't have the time to get it rebuilt as this is my DD, and with me being on call during the week I never know when I'm going to have to go to work..
Xpress is offline
post #5 of 11 Old 10-21-2011, 11:39 AM
LeeIndy
buy a new one and keep the old one as a spare. it will work in a pinch if your new one goes out on the side of the road.
LeeIndy is offline
post #6 of 11 Old 10-21-2011, 11:52 AM
Que89YJ
Replace and upgrade. Lood at the alternator mod in the FAQ. You need the GM alternator CS 144 mod. Well worth it. You can get one from a bone yard for $30.
Que89YJ is offline
post #7 of 11 Old 10-27-2011, 05:38 PM Thread Starter
Xpress
Okay, I was messing around in the Jeep last night ,and noticed that when the heater sounds like it bogs out, it's actually putting out a LOT more air. Only happens when the rpms are low and I feed in more gas to get up to speed.
What the hell?
Xpress is offline
post #8 of 11 Old 10-27-2011, 10:29 PM
Flajeeper1
1987 YJ Wrangler
Not sure on your problem but clean all ground connections from frame to engine. As for and alternator I suggest going to the CS144 alternator. I upgraded and went to a 1 wire alternator with 140 amps, same alternator bracket with minor adjustments. You'll have all the electrical power you need. You can also collect all your parts, take an afternoon to replace the alternator and then turn in your old alt. for the core charge. I also upgraded to a larger battery.
Flajeeper1 is offline
post #9 of 11 Old 10-28-2011, 09:36 AM
Que89YJ
Sounds to me like your vacuum controls are not set up correctly and you are dropping the vacuum to the switch. If you had a voltage issue you should be able to see dimming in the headlights.
Que89YJ is offline
post #10 of 11 Old 10-28-2011, 09:40 AM
Que89YJ
Read this:
http://www.jeepforum.com/forum/f12/m...es-why-499877/
Go into the FAQ under heating. Amazing amount of info there.
Que89YJ is offline
post #11 of 11 Old 10-28-2011, 11:19 AM Thread Starter
Xpress
Well now.. It appears that someone had plugged both vacuum lines into each other. I'll plug them back into the heater controls later, but for now the heater is baking me out. Had both windows down with it being a cool morning (about 65*F) and I was being BAKED inside my Jeep
Don't think I'll have issues with keeping warm going down the highway even with my leaky top.
Xpress is offline
Electrical Gremlins TheRussGrant YJ Wrangler Technical Forum 3 01-18-2010 08:27 AM
Electrical gremlins Futaba YJ Wrangler Technical Forum 0 06-13-2008 06:18 AM
Electrical Gremlins?? omarkhan860 TJ Wrangler Technical Forum 3 05-20-2008 05:03 PM
Blower Motor Gremlins sargroup TJ Wrangler Technical Forum 12 12-18-2007 07:06 PM
Help! : Electrical Gremlins ecupir8 TJ Wrangler Technical Forum 7 08-19-2002 10:25 AM
