#1 | |
More About Aussie lockers
Hey, What can you guys tell me about the Dana30 Aussie Locker for my 90 YJ ? like things needed to install , how to and that and well i know its defnitly worth it but street wise and what not ? just some info and if there are any better ones for around 290.00$ ish ...or what you would recommend , but i dont have the $ to drop a detriot or ARB
thanks !
1990 YJ ,2.5 AX-5 4.10's 4.5'' l 33''hawgs, 2KC's 2 55watt, Custom Bar, Discos. -- An Finally got a Softop!!!! [SIZE="1"] [QUOTE] " I'd Hate to Advocate Drugs, Violence, Guns or Insanity .. but they have always worked for me" - Hunter S. Thompson [/QUOTE] Jeep Build - 11,550$ [/SIZE] [COLOR="Lime"]Sunday.Drivers.[/COLOR] |
#2 |
aka Jamesx2
Heres a good write up
http://www.4x4xplor.com/aussielocker.html Theres a few other write ups on the net I have the aussie up front. As far as I am concerned the aussie IS the best. On the dry road you dont even know its there. The Aussie takes me everywhere i want to go off road As far as things needed to install, your going to need a torque wrench, thers no way around that unless you want to screw things up. A vise helps too. Brake fluid to break the suction of the carrier in the diff. I had to use a pry bar to remove the carrier. Make sure you dont put the springs where the pins should be and the pins where the springs should be. I did, reininstalled, did the spin test and failed. So i guess you can say i did it twice. Be careful with thise springs, they can fly !!! Also have a plastic wrap ready to cover the bearing caps after removal to keep them dirt free. DIRT KILLS!!!! Thats all I can think of off the top of my head. Also go out and buy the gasket for the diff cover, dont waste your time with RTV , its too messy |
#3 |
Thanks! , Yeah Ive seen em around and im really thinking about them becuase of the cost of the install its relatively cheap.... Figured its something I can work for , once i get a job
#4 |
aka Jamesx2
Are you in Plainfield NJ? Is a bit far to me to come help. sorry. You will be fine. Just take your time
#5 |
aka Jamesx2
Your paying someone to do it?
#6 |
with the locker once u put it into 4wd low/high and engage the front axle the locker should engage right ? and no plainfield illinois and im going to do it myself with my uncle who is a mechanic for MACK trucks
#7 |
Dreaming of Moab
Yes...automatic locker.
#8 |
aka Jamesx2
Order it from these guys. The source.
http://www.aussielocker.com/item.php/TMd1d4cf/1aae/20/320002/.html They have nice tech support. Heres a paragraph from their page The Aussie Locker relies on a simple and highly innovative mechanical design which makes use of two distinct sets of forces, "ground driven" forces acting on a wheel when cornering (forces the outside of the wheel to turn faster) and the engine driven forces through the drivetrain. The combination of these two sets of opposing forces and the unique Aussie Locker design allow the automatic locking an unlocking of the driving gears when a vehicle turns or requires differential action. Theres alot more info there on the site. To answer your question.... Yes, it engages when its needed |
#9 | |
hey fataltherabbit,
i have wheeled mine 2 times now with my aussie up front. i absolutely love it!!! one thing i would tell you not to do... when re-assembling the front pass side intermediate shaft back in the carrier, DO NOT put the c-clip back on (if yours even has one)..the directions say to put it back on when re-installing the axle and carrier, but if you do this you'll have a difficult time getting it back out if you have to...you'll know what i mean when you are putting it back together oh yeah, i got mine from these guys... Quote:
i hope this helps
STUPID HURTS.......OUCH!@#$ |
#10 |
Although I have a DD I drive my Jeep on road ALOT. I installed an Aussie and love it. Listen to everyone here, read the old posts, they are great. Silent on road and I mean silent. The only thing to remember is you will have to have the front driveshaft balanced(Well I did). It will be spinning all the time so I got a vibe. Plus some say you will lose a little MPG, if that matters to you. You also have to keep the axle disconnect factory or posilok.
Its a great investment for traction purposes. |
#11 | |
#12 |
H2 Recovery Team Member
one thing to keep in mind is it will actually engage before the front axle does. even if the pass side doesn't engage (ie you have a selectable system like the posilok or a faulty vac system that doesn't lock up right away) the locker will still drive the driver side wheel as soon as you put power to the front drive shaft.
RIP: '88 YJ 2.5L Ax-5 NP231 Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front. 92 YJ 4.0L Ax-15 231 5" springs, 1" shackle 31's or 35's depending on my mood |
#13 | |
#14 |
i´ve got the aussie locker installed in front/rear and i love them...in connection with the 35´s cooper stts under normal circumstances i get where i want to...
´79 CJ V8 ´94 ZJ V8 Ltd. Sold: ´91 XJ, ´01 XJ, ´91 YJ, ´99 WJ, ´93 ZJ |
#15 | |
Then with the pass axle locked (vac or posilok)the two are truely "locked". |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
