Mopar 5.2 swap radiator hoses? - JeepForum.com
post #1 of 3 Old 09-17-2011, 12:39 PM Thread Starter
czjeeper
I have been looking around, and am collecting information on the best hoses to use for my 5.2 swap.
I've got the conversion radiator from Oconee Offroad.
What hoses have you guys used for this swap?
I found a reference to a Napa upper 7718, and a Napa lower 8333.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #2 of 3 Old 09-17-2011, 01:17 PM
mike_breaker_5
i made a franken-hose to fit a stock 99 tj radiator. (same as the stock yj rad just it's alum and plastic)
you should just be able to use stock zj hoses i would think?
maybe a little trimming may be needed but worth a test fit anyhow.
if your napa is as cool as mine (they know nothing on my jeep is stock) they may let you take the hoses out to your rig and test fit them before buying. at very least pay for them, take em home, and test fit. no worky, just return them. i have done both of these countless times in my hometown napa store.
the upper may even be able to be all flexy hose with an anti kink spring inside. the lower however is tricky due to being so close to the pulleys.
like i said i did not use a conv rad but if i had (if i wasn't poor i would have) i think the zj hoses may have reached may have needed a little extension or a trim but it may be worth checking into.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #3 of 3 Old 09-17-2011, 04:48 PM
444
I used one of these type universal kits on my 440 with aftermarket rad in my old plymouth.
444 is offline
Radiator Hoses. Help 2ACR TJ Wrangler Technical Forum 8 09-30-2010 09:01 PM
silicone radiator hoses stanware JK Wrangler Technical Forum 5 06-28-2010 06:06 PM
Radiator hoses.... GCarpJeep YJ Wrangler Technical Forum 7 01-29-2009 07:27 PM
Radiator/Heater Hoses jquest1 TJ Wrangler Technical Forum 3 01-28-2007 02:01 PM
Radiator flush and hoses Fargo TJ Wrangler Technical Forum 10 08-03-2006 11:19 AM
