Modifying Warn Bumper - JeepForum.com
post #1 of 2 Old 02-24-2010, 01:57 PM Thread Starter
digizure
Hello, I have a Warn bumper and I was wondering if there is any way to modify it to tow a small trailer? What are the requirements for towing?
The bumper has 6 holes to put the bolts through and two bolts under. There are L brackets to bolt to the frame. Is this enough for a small tow? I plan to build a small trailer for camping gear, etc.
Maybe I should weld two more brackets to run a chain through?
Any inputs appreciated. Thanks.
M
digizure is offline
post #2 of 2 Old 02-24-2010, 02:02 PM
sebastian22
The Warn rear bumper should be good enough the way it is, the only thing you will need is something to tie your trailer chains to.
95 Black YJ
sebastian22 is offline
Bought a used bumper/tire carrier and now I need help modifying it stangman68inftc TJ Wrangler Technical Forum 3 09-21-2008 10:44 PM
Stock bumper winch plate on Warn bumper? TJamz TJ Wrangler Technical Forum 6 06-29-2008 04:08 PM
Recovery with Warn rear Bumper and Warn Shackle Bracket littlebrother TJ Wrangler Technical Forum 2 03-02-2008 08:06 PM
Warn front bumper, Warn mounting plate and milemarker winch....will this work? Sparty TJ Wrangler Technical Forum 1 01-11-2006 02:13 PM
Warn Bumper greenmachine99 TJ Wrangler Technical Forum 12 03-20-2005 11:48 PM
