Missing thermostat? - JeepForum.com
post #1 of 4 Old 12-30-2001, 04:09 PM Thread Starter
gasheadbox
Missing thermostat?
Felt that my 95YJ had a thermostat problem as the gauge barely went over 100 so I decided to replace it. When I took the housing off, to my suprise there was no thermostat to be seen just lots of sealant. Can anybody think why the previous owner decided not to spend $5 and replace it? A new one has gone in and works fine but it just seems so odd and concerns me that it may have been taken out to hide another problem. Any ideas?
gasheadbox is offline
post #2 of 4 Old 12-30-2001, 04:20 PM
glm 87 wrangler
Well what most likly happen was they had an over heating problem and found out it was the thermostat.So they pulled it out and went on there way.I have done this myself many times but I tell myself or if its not my car to install a new one when you get a chance.But i guess the person who own it before did not.
The thermo brings the jeep to operation temp quickly as possable and tries to maintain it
as best it can.But with out it,it puts too much water in the system and never gets to operating temp.But in an emerg.situation you can run without it.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 4 Old 12-30-2001, 10:44 PM
SFM1AE2
I would install one asap. Without one your engine may be running hotter than you know. When your engine is at operating tempature the thermostat regulates the amount of coolant flow. Without one the coolant moves to quickly through the block to allow an exchange of heat from the block to the coolant to be disipated by the radiator. So while your guage reads 100 for coolant temp your block may be getting to hot causing long term damage. My 2 cents.
87YJ I-6 Offenhauser intake Holley 4bbl MSD 6AL box
SFM1AE2 is offline
post #4 of 4 Old 12-31-2001, 10:50 AM
Big92Jeep
I would suggest a 160║ SuperStat from advanced auto parts!
~RýCK
2008 Unlimited Rubicon
"The weather is here, I wish you were beautiful"
Big92Jeep is offline
Thermostat for 98' TJ 2.5L DavidJohnson TJ Wrangler Technical Forum 3 12-23-2009 03:49 PM
'90 YJ missing thermostat AidanMullen YJ Wrangler Technical Forum 3 02-24-2009 07:29 AM
Thermostat meanstreak02 YJ Wrangler Technical Forum 6 06-24-2008 06:30 AM
New Thermostat Black01TJ TJ Wrangler Technical Forum 11 07-13-2007 02:49 AM
new thermostat 92yjncal YJ Wrangler Technical Forum 1 07-04-2004 01:42 AM
