Missing at idle - JeepForum.com
post #1 of 6 Old 04-03-2013, 03:24 PM Thread Starter
merrell056
Missing at idle
Hi everyone. I recently bought a YJ with a weber carb. It has been nuttered. It had an exhaust leak so I pulled the manifolds and replaced the cracked exhaust manifold. I also pulled the valve cover to clean it and replace the valve cover gasket.
The problem I am having is that at idle the motor misses and dies. When revving it has no issues whatsoever. Here is the list of what I have done so far to try and fix it. I am at my wits end and hope you all can help me.
1. New distributor cap, rotor, plugs, and wires.
2. Checked all post nutter vacuum lines based on threads I have searched on these forums.
3. I have some extra electrical sitting in the engine compartment that I haven't had a chance to get to. It is all pre-nutter wiring.
4. Went through all 6 plugs and disconnected them all 1 by 1 and the missing was worse on each of them. No single plug seems to be the problem. Plus when i rev the motor it does not miss at all. It does when I revved with each of the spark plugs disconnected.
Could this be a problem with the EGR valve? Timing? I have been searching the forums for hours. Maybe I'm not searching for the right thing but I'm about to tear my hair out.
merrell056 is offline
post #2 of 6 Old 04-03-2013, 03:26 PM
Old4X
1990 CJ7
What were your latest compression test readings?
What is your vacuum at idle? Needle steady or moving?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 6 Old 04-03-2013, 03:36 PM Thread Starter
merrell056
I don't have the tools to test but I can get them. It idled just fine before I changed out the manifold.
post #4 of 6 Old 04-03-2013, 03:52 PM
Old4X
1990 CJ7
That really points to a vacuum leak
Old4X is offline
post #5 of 6 Old 04-03-2013, 04:09 PM Thread Starter
merrell056
I will go over my vacuum work again.
post #6 of 6 Old 04-03-2013, 05:18 PM Thread Starter
merrell056
I found that one of the distributor to CTO valve ports was broken on the CTO valve. Anyone know where I can find one? Dealership isn't answering, of course, and it doesn't seem to be anywhere on the local autopart stores' websites.
