missing cylinder? anyone - JeepForum.com
post #1 of 3 Old 06-05-2011, 04:10 PM Thread Starter
dwdrums40385
ok, i went to the local riding spot and while i was driving through a field, i gave it some gas and it backfired (i think), then the check engine light came on, and it was idling, running really rough. so i looked under the hood, and there was oil dripping from the PCV valve, with oil in my air filter, oil was around the valvecover, i checked, and still had plenty of oil. so i left, and drove it home, it ran rough all the way here and when driving everything was shaking and rattling. it isnt smoking or anything. i pulled the spark plugs, none of them are fouled, i just put a new distributor cap/button, wires on. i am pretty sure there is a cylinder missing. i wonder if it could be an o2 sensor or something?
so, i think all of that has something to do with it. is there any way to check for error codes on a 93 yj, without a computor diagnostic tool thingy.
so... have any of you guys experienced this? or what do you think?
1993 YJ 4 banger- cold air intake, 31" matercraft MT's, 1" boomerang shackles, bedlined rockers, Proline beadlock simulator rims, bedlined shorty corner guards, Bed lined tub, homebrew power steering skid, LUK stage II performance clutch.
dwdrums40385 is offline
post #2 of 3 Old 06-05-2011, 06:39 PM
TheNewbie
http://www.jeepforum.com/wiki/index....k_Engine_Codes
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 3 Old 06-05-2011, 07:59 PM Thread Starter
dwdrums40385
thanks, i tried to use the codes, but i kept loosing track of the breaks. i kept looking around, and found that it's the O2 sensor, i crawled under there, and realized that i ripped the wires out. i went back to the wheelin' spot and found 3 feet of wires in the weeds, so i taped the rest back up, but i still need a new O2 sensor since the wires are ripped about 1/2 of a centimeter away, and they are to short to tape back up.
thanks for the help! at least i'll know what do next time that stupid light comes back on.
89 TBI 4 Banger missing a cylinder; does ECM know which is firing? EABiker YJ Wrangler Technical Forum 2 01-06-2011 12:33 PM
missing cylinder and rpm cut off johnnyw104 TJ Wrangler Technical Forum 12 03-14-2008 10:26 PM
TJ missing in cylinder 3 jeepdad1 TJ Wrangler Technical Forum 7 04-12-2007 03:07 PM
Missing Diaphragm in Clutch cylinder GooseAbuse YJ Wrangler Technical Forum 2 03-04-2007 07:12 AM
'95 YJ 2.5L 4 Cylinder Engine Missing Steve Midgett YJ Wrangler Technical Forum 1 03-03-2004 06:41 PM
