Quantcast Missing bolts... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Missing bolts...
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 04-01-2007, 09:23 PM   #1
EJames1226
Missing bolts...
Can anyone tell me what size bolts to get for these...
Top of the power steering pump.
And then in that same picture, on the very left on the exausht manifold, theres a bolt missing, any idea what size that is?
Finnaly in this last picture, there is a hole to hte left of the other missing bolt on the exauhst manfiold. This picture shows all three missing bolt spots.
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline   Reply With Quote
Old 04-01-2007, 10:14 PM   #2
Burnerman
The exhaust bolt should be 3/8- 18. You're also missing the nut and washer on the second stud in for the intake/exhaust. The P/S may also be 3/8 but I dunno how long. Just go to a hardware store or Tractor Supply. Take the heep and see what fits.
89' YJ Larado 4.0L,AX15
01' Grand Cherokee 4.0L
Check my Gallery for pics.
My Rebuild Thread
Take a minute and fill out your profile, Please
Burnerman is offline   Reply With Quote
Old 04-02-2007, 04:33 PM   #3
92 Green YJ
Head Brewmaster
92 Green YJ's Avatar
hmmm, if im not mistaken that power steering box bolt uses a goofy thread pitch and thread taper on it, might not be able to find that at the local hardware store. best bet might be to go to a junkyard and poke your head around under some XJ hoods for the bolts you are missing. Had to do that when I sheared off a steering box bolt
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote
Old 04-02-2007, 06:02 PM   #4
EJames1226
Good idea, i should just go to the junkyard and take all the bolts i need.
Old 04-02-2007, 06:10 PM   #5
92 Green YJ
Head Brewmaster
thats what i would do. Like i said some of those use goofy thread pitches, and i would rather use stock bolts anyway so the heads are all the right size. makes it easier when you are doing maintenance
Glock Forum
