Miss firing cylinder? - Page 3 - JeepForum.com
post #31 of 55 Old 04-08-2011, 06:44 PM
Que89YJ
You have a bad ecu. Check for power at pins 3&9. If you have power there then replace it.
Que89YJ is online now
post #32 of 55 Old 04-08-2011, 11:58 PM Thread Starter
kc10er
ty will do with test light
kc10er is offline
post #33 of 55 Old 04-13-2011, 04:29 PM Thread Starter
kc10er
pins test good, just put in a new ECU. still won't start. Getting mad as hell now guys (not at you guys)... WTF.
kc10er is offline
post #34 of 55 Old 04-13-2011, 05:32 PM
NonRubicon
Have you ruled out the ignition module, coil or the distributor?
NonRubicon is offline
post #35 of 55 Old 04-13-2011, 05:55 PM
pasinbuy
I just read your whole thread. Your problem sounds like one I had a while back. Driving along and motor would skip a beat for no reason. For the life of me I could not figure it out until it died going down a road.
The CPS was the problem. The book said disconnect the CPS plug, wait a minute, plug it back in. If your YJ starts you know that it was the CPS, go buy a new one.
Good luck,
Martin
One more thing, Please fill out your profile, it helps us to help you.
pasinbuy is offline
post #36 of 55 Old 04-13-2011, 06:12 PM Thread Starter
kc10er
Whole new ignition side, ALL of it. We got spark
Good luck,
Martin
CPS was swapped, no results. ALL sensors changed. It was starting on three cylinders, changed the injector, now no start. Will fill out profile.
TO ALL: Someone take a picture of this so-called fuel rail ground. I don't have a single loose wire anywhere, but want to check the location. Thanks.
kc10er is offline
post #37 of 55 Old 04-14-2011, 09:17 AM
Que89YJ
Hey KC. I'm going to PM you my number. Give me a call.
post #38 of 55 Old 04-15-2011, 10:46 AM Thread Starter
kc10er
Que: I have checked the play in the dist. as asked. I'll call ya after work today.
Thanks Que and everyone else. Hope we are on the right track finally. I'll keep you all updated.
kc10er is offline
post #39 of 55 Old 04-19-2011, 12:08 PM Thread Starter
kc10er
UPDATE: Slack in the timing chain and dist. play is good. Set engine to TDC and checked to make sure the rotor on the dist. was at 3 o'clock and it was. Still no start, just cranks and cranks and cranks. Running out of things to replace and money to do so
Could my code 41 "alternator field open or shorted" be causing my original rough idle and now no start condition?
kc10er is offline
post #40 of 55 Old 04-19-2011, 01:02 PM
Que89YJ
I'm dealing with my dad going into surgery in a few. Haven't had time to follow up. I'm thinking the pickup or distributor. Check voltages at all your sensors. I wish someone was close by you could swap out sensor with to Troubleshoot.
post #41 of 55 Old 04-19-2011, 02:09 PM
kelti819
kc pm me your number im coming through your area in the am and may be able to help. que has helped me a lot and i have learned my way around my 92 2.5l with his help here lately. ill see what i can do.
kelti819 is offline
post #42 of 55 Old 04-19-2011, 02:18 PM Thread Starter
kc10er
thanks a lot man! Just got off the phone with Que and I am shooting ya a PM now.
kc10er is offline
post #43 of 55 Old 04-19-2011, 07:38 PM
spawn12348
Sounds like the problem I had when I first got my jeep . It would lose power untill one day it just died on me
could not get it to run for the life of me unless I dumped some gas down the carb . Turned out the top of my gas tank was rotting and bits of the rust clogged my lines and blocked my in carb fuel filter , 350 bucks later and I replaced the gas tank and the filter and she fires up fine
spawn12348 is offline
post #44 of 55 Old 04-20-2011, 04:19 PM Thread Starter
kc10er
i am injected and have 31 psi at the rail. I also visually saw each injector squirt fuel so I do not think there is a problem there. Replacing the pump and other fuel components will be a last resort as i have a full tank.
Update: Looks like I will be able to replace the dist/pickup via help from Max. I'll keep you guys updated. Thanks for hanging in there with me guys.
kc10er is offline
post #45 of 55 Old 04-26-2011, 01:09 PM Thread Starter
kc10er
The pickup sent was the wrong one so I'll just replace the whole dist and pickup next month.
Update after replacement.
kc10er is offline
89 TBI 4 Banger missing a cylinder; does ECM know which is firing? EABiker YJ Wrangler Technical Forum 2 01-06-2011 11:33 AM
flat dead miss in cylinder...what to do? Bmcclain YJ Wrangler Technical Forum 12 10-07-2009 12:18 PM
AMC 4.3L Intermittent Cylinder Miss Cheney YJ Wrangler Technical Forum 0 07-16-2009 04:28 PM
Removing center console lock cylinder from latch cylinder Dstompe TJ Wrangler Technical Forum 11 06-27-2009 07:01 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
