Mirror relocate - JeepForum.com
 2Likes
  • 1 Post By DirtKar
  • 1 Post By Mr.B
post #1 of 10 Old 10-22-2012, 04:40 PM Thread Starter
fisyac
Mirror relocate
Have a 1991 yj I put t 40 torqes and the bolts spin but do not come out on bottom side of windshield hinge any suggestions
fisyac is offline
post #2 of 10 Old 10-22-2012, 05:15 PM
jokerchief462
The nut is spinning in the framework. You can try prying a screwdriver under the hinge to keep it tight and see if it will start to come loose.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 10 Old 10-22-2012, 05:30 PM Thread Starter
fisyac
Thanks I'll try that
fisyac is offline
post #4 of 10 Old 10-22-2012, 05:40 PM
jbolty
jbolty's Avatar
there are nuts up inside the tub buried in seal sealing goo. You can get up there with small hands or tilt the windshield and take the dash off; not as much work as you would think
jbolty is offline
post #5 of 10 Old 08-23-2017, 07:41 AM
fdub
would someone please help
Im really confused i need to relocate my factory mirrors to pillar A so when i take the doors off there's nothing else to do mirrors are there and ready to go i have a 2002 wrangler 2-door, so I'm hoping someone could supply me with a link as to a kit they've purchased and really likes it that would work on my 2002 wrangler. Thank you!
fdub is offline
post #6 of 10 Old 08-23-2017, 09:41 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Originally Posted by fdub View Post
im really confused i need to relocate my factory mirrors to pillar A so when i take the doors off theres nothing else to do mirrors are there and ready to go i have a 2002 wrangler 2-door
Welcome to the forum. There's lots of different ways to have mirrors without doors. Here in the YJ forum, you can search for it quite easily. But you have a TJ, so there might be some differences. This is what I use, and I believe the write up was done on a TJ. I like them because I can swing them all the way into the cab, when I on the trail.
http://www.4x4xplor.com/doorless-mirror.html
You really should check in the TJ forum though.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #7 of 10 Old 08-23-2017, 11:11 AM
DirtKar
I pledge allegiance.
DirtKar's Avatar
You're using a brake distribution block to mount your mirrors, Mr.B?
Mr.B likes this.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #8 of 10 Old 08-23-2017, 11:35 AM
Mr.B
Mr.B's Avatar
Haha! Too much copy and paste. Fixed it.
DirtKar likes this.
Ham license:
Everyone is Welcome
Mr.B is offline
post #9 of 10 Old 08-24-2017, 09:47 AM
fdub
Thanks Mr. B that's really interesting!
fdub is offline
post #10 of 10 Old 08-24-2017, 10:54 AM
Mr.B
Mr.B's Avatar
The only thing I added to the set up, was a star washer between the mounting arm and the top of the bolt. That keeps it from moving at high speed.
Ham license:
Everyone is Welcome
Mr.B is offline
