Minor but annoying electrical problem - JeepForum.com
post #1 of 2 Old 04-06-2008, 05:01 PM Thread Starter
Cross
Okay, I seem to have a loose wire or the insulation has worn off a ground wire somewhere. Whenever I hit a bump my dome light and interior light under the dash comes on. Hit another bump and it goes off. I have checked around the switch where the doors turn the lights on and off and nothing is wrong there. Sometimes while parked the light will come on. The shacking from shutting the door will turn it off.
I know some of you guys have done a good amount of electrical work and might be able to tell me some areas to look.
Cross is offline
post #2 of 2 Old 04-06-2008, 05:06 PM
flkeysff
You might unscrew the light under the dash and pull it down slightly to find a plug that it is connected to. One of the wires had worn on the emergency brake bracket on mine causing it to short. Hope this helps
85 CJ7, shown in pic, getting a new pita body and way too much money spent on making it look pretty!
88 YJ (bought for my daughter) still my project!
90 YJ (bought for me) gutted everything going to start from the ground up! Plans include new interior, roll cage, dash, 5.0l 302, 8.8 rear, SOA lift, stainless lines and any other thing I can spend money on! At least until my wife finds out!!!
flkeysff is offline
Jeep is having electrical problems and its getting annoying BamaLonghorn TJ Wrangler Technical Forum 14 01-15-2009 01:06 PM
Minor Clutch Problem HanksRide YJ Wrangler Technical Forum 1 01-08-2009 08:08 PM
Need advice, have a minor problem with backspacing MZP TJ Wrangler Technical Forum 2 06-01-2007 05:56 AM
1" BL minor problem ricky TJ Wrangler Technical Forum 10 07-19-2005 11:18 AM
Troubleshooting minor problem lifeguard4_00 YJ Wrangler Technical Forum 1 12-15-2003 03:48 PM
