mini spool in an 8.8 - JeepForum.com
post #1 of 25 Old 04-13-2007, 09:10 AM Thread Starter
95builtjeep
Is anyone currently running a mini spool in an 8.8? if so, what do you think and do you think its a good modification? i drive about a thousand miles a year on my jeep. its pretty much seasonal. i wheel about once a month or so and i want something better than the limited slip in the rear without the price and the quirks. i'm also running 37" irok radials if that helps and i've got a dd.
95builtjeep is offline
post #2 of 25 Old 04-13-2007, 10:31 AM
drexelsteve
Don't let any naysay'rs tell you different. I've had a spool in the rear of my dd for years and i love it. Very predictable, gnarly traction, and i haven't noticed any accellerated tire wear. Thousands of miles later and it's still the bomb. Best bang for the buck besides the actuall 8.8 itself.
13 Rubi
drexelsteve is offline
post #3 of 25 Old 04-13-2007, 12:24 PM
mosefer
I've read that a full spool is the hot ticket, and that a mini spool will explode in the rocks.
'89 YJ, 258 with 4.0L head, AX-15, 8.8 w/Detroit, HP30 w/TJ shafts & OX locker, 4.56, SYE, 4" springs, 9000E MM winch, 33" KM's and twin flashlights!
mosefer is offline
post #4 of 25 Old 04-13-2007, 12:35 PM
92 Green YJ
92 Green YJ's Avatar
FYI, if you have the limited slip already, a mini spool may not fit in the LS carrier. I do know for a fact that most lunchbox lockers for the 8.8 will not fit in the LS carrier so you may need to change out to an open carrier to do a mini spool. that means you would also need to re- set up your ring and pinion.
Personally, I went with an ARB in my 8.8 and I would never use anything else. I LOVE it. complete traction with the flick of a switch, and an open diff for when I need to drive my YJ on the street. When i swap out my Dana 30 I'm going with an ARB up front too
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #5 of 25 Old 04-13-2007, 12:36 PM
MLJeeper
MLJeeper's Avatar
For the limited mileage your traveling, run the spool.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #6 of 25 Old 04-13-2007, 12:39 PM
MLJeeper
MLJeeper's Avatar
yep forgot about that
MLJeeper is offline
post #7 of 25 Old 04-13-2007, 01:25 PM
atomicmoose
Just call me Moose
atomicmoose's Avatar
ARB lovin'
ARB = $700+
Spool = $250ish
Spool FTW!
atomicmoose is offline
post #8 of 25 Old 04-13-2007, 02:06 PM
2nd YJ
On a side note, I asked a question on another thread here last week. To run a full spool on an 8.8, you have to get rid of the c-clip axles. So, wouldn't it be the same for a mini spool? I know the differences between the two (full vs mini), but not sure if the mini would have the same issue with c-clip axles. Just something to question and potentially look out for.....
2nd YJ
93 Wrangler - 8.8 LS rear - D30 Aussied - Yukon 4.88 R&P - TW driveshafts Front and Rear - AA SYE Kit - RE 4.5" ED Lift - M.O.R.E. Shackle Reversal - 35" Kuhmo MT - TJ Flares
2nd YJ is offline
post #9 of 25 Old 04-13-2007, 03:22 PM
92 Green YJ
Originally Posted by atomicmoose
ARB = $700+
Spool = $250ish
Spool FTW!
ARB = $600, flexibility, streetability, reliability, Quality ......... Priceless
A spool is all well and good for a trail only rig, but if its street driven, i say go selectable that way you have the option.
Besides, if its true that you need to eliminate the C-clips to run a spool
Spool = $250
Open Carrier = ~ $90
Master Install Kit = ~$85
Superior Super 88 kit = $350 or so as I recall
Total to run a spool in an 8.8 = ~$775 and thats if you do the installation yourself as opposed to paying a shop to do it. Most shops will charge at least $300 bucks to do a gear set up in an axle
My
post #10 of 25 Old 04-13-2007, 04:34 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Scott,
David at Northridge4x4 was having an introductory sale for the Super 88's for ~$530 including shipping. Not sure if they are available elsewhere for less.
You just got the 3 & 5 numbers mixed-up.
Joe Dillard is offline
post #11 of 25 Old 04-14-2007, 01:31 AM
92 Green YJ
thanks Joe, i thought that was low when I typed it. so yeah that makes the spool even more expensive
My
post #12 of 25 Old 04-14-2007, 06:20 AM
atomicmoose
Just call me Moose
Didn't think any carrier was needed for a full spool.
post #13 of 25 Old 04-14-2007, 07:39 AM
notmyj
I havea mini spool in my 8.8. I DD mine on 33's, soon to be alot bigger. The mini spool will be fine but since your on 37's, I would reccomend a few things... Alloy shafts would be a good upgrade, and the limited slip carrier in the 8.8 is weaker than the open carrier. When you install the mini spool, you should shim the side lugs (the parts that spline to the axles, to make sure you have a snug fit for the center blocks. Be sure to shim each side equally so that the cross pin will still line up though.
If you decide to go with a full a spool you will need to get a clip eliminator kit. If you do, make sure that t will fit behind disc brakes, if you have them. As far as I know, Superior is the only one that has a kit that will fit under discs.
Atomicmoose, is correct. With full spool you need no other carrier, as the spool is the carrier. The ring gear bolts to the full spool. A mini spool is just inserted into the existing carrier.
If you need an open carrier let em know... I have a brand new one, still in the box sitting on my shelf.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #14 of 25 Old 04-14-2007, 10:49 AM
bogger jeep
weld the spiders and save the money for something else.i've ran welded for years and know a lot of other guys that do the same .
bogger jeep is offline
post #15 of 25 Old 04-23-2007, 12:17 PM
bryan-2kevo
you can get a mini at http://www.drivetrainspecialists.com...-88/index.html for $81!!!!
love it
bryan-2kevo is offline
Locker V. Spool V. Mini Spool yjdrvr YJ Wrangler Technical Forum 15 05-14-2007 06:06 PM
Mini Spool? LeeGro TJ Wrangler Technical Forum 2 11-10-2006 11:53 AM
Mini Spool Installation firejeepster YJ Wrangler Technical Forum 2 07-07-2006 05:37 AM
Mini spool Quarry Adams TJ Wrangler Technical Forum 3 07-08-2005 07:38 AM
mini spool? brubaker YJ Wrangler Technical Forum 3 02-21-2005 09:54 AM
