is mine an '87 - JeepForum.com
post #1 of 17 Old 08-07-2013, 05:09 PM Thread Starter
jhrebs
1987 YJ Wrangler
is mine an '87
So I was under the impression that I had an '87 4 cylinder fuel injected. But how do I confirm any of this? After reading alot of posts and talking to guys I have no idea what I got. I know I have an NP231. I do know it is 4 cylinder AND fuel injected. But not sure what year. This inquisition all started because I am trying to get parts to install power steering and want to make sure everything i buy is correct.
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #2 of 17 Old 08-07-2013, 05:21 PM
Rproject
1987 YJ Wrangler
This if from the 87-88 FSM and will identify your engine:
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 17 Old 08-07-2013, 05:38 PM
GrantYJ
If it has injectors on a fuel rail where the intake meets the head, it's MPFI (92 or newer). If not, it's throttle body injected and it's a 91 or older.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #4 of 17 Old 08-07-2013, 06:03 PM
tdewit
I'd say '90 or older. I have a '91 with injectors on a fuel rail where the intake meets the head.
tdewit is offline
post #5 of 17 Old 08-07-2013, 06:04 PM Thread Starter
jhrebs
1987 YJ Wrangler
I found a casting number 8933004200. After some searching I am guessing my engine is an 89. very interesting. Maybe the engine was replaced at one time or my jeep is really an '89!!
jhrebs is offline
post #6 of 17 Old 08-07-2013, 06:08 PM
Rproject
1987 YJ Wrangler
Check this out.
1996 White ZJ
Rproject is offline
post #7 of 17 Old 08-07-2013, 06:09 PM
rykemc
Call the dealership with your VIN#. They can tell you what year your jeep is based off the VIN# Or if you like, post your VIN# or PM me your VIN# and I can look it up for you on my system
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #8 of 17 Old 08-07-2013, 06:11 PM Thread Starter
jhrebs
1987 YJ Wrangler
It is throttle body fuel injected
jhrebs is offline
post #9 of 17 Old 08-07-2013, 06:26 PM Thread Starter
jhrebs
1987 YJ Wrangler
well according to these numbers i think it is an '87. so confusing
@rykemc 2BCHV81S8HB-544342 I think i got it correct. Thanks for the help, everybody!
jhrebs is offline
post #10 of 17 Old 08-08-2013, 06:36 AM Thread Starter
jhrebs
1987 YJ Wrangler
or the VIN could be 2BCHV8HB544342
jhrebs is offline
post #11 of 17 Old 08-08-2013, 09:11 AM
LJameson
I just looked up your vin on TechCONNECT (chryslers service site), and your vin does come up as an 87 YJ.
1990 YJ
LJameson is offline
post #12 of 17 Old 08-08-2013, 10:33 AM
rykemc
Correct. I came up with an 87 as well.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #13 of 17 Old 08-08-2013, 12:25 PM Thread Starter
jhrebs
1987 YJ Wrangler
so it is an 87. That's good. But maybe somebody put in an '89 engine? What about the tranny. I know i have the NP231 cause of a metal tag affixed to it.
jhrebs is offline
post #14 of 17 Old 08-08-2013, 12:29 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sounds like a motor swap at some point. I don't doubt that the tub vin is an 87 but signs point elsewhere for the drivetrain.
Luck Favours The Prepared
Anticanman is offline
post #15 of 17 Old 08-08-2013, 12:34 PM Thread Starter
jhrebs
1987 YJ Wrangler
Are there any other things i could look for to make sure about the engine. So far every part I bought for my so called '87 fit.
jhrebs is offline
