metal dash backing - JeepForum.com
post #1 of 9 Old 08-24-2009, 08:00 PM Thread Starter
CostaRicaJeep
metal dash backing
I just folded the window down and RUST all over the metal dash backing (and newly broken window hinge). I've ordered the window hinges, but I've been looking on the internet for a new (or used) dash backing, and can't seem to find one. Anyone know where I can get one?
CostaRicaJeep is offline
post #2 of 9 Old 08-24-2009, 10:47 PM
rodneyt
1987 YJ Wrangler
dash
i just through one away i held it for a few months and thought that no one is going to want this so i chucked it.you should check out a recking yard or somr thing in that area good luck
rodneyt is offline
post #3 of 9 Old 08-25-2009, 04:31 AM
Dislsmoke
no one makes them, you could find one in a salvage yard or just do a flat dash.
85' CJ-7, 258, T-5, D-300. Soon to be 360, t-18,d-20
4" skyjacker, 33's, frame up resto, Custom built everything else.
Custom Dashs built to your specs
website.
Dislsmoke is offline
post #4 of 9 Old 08-25-2009, 09:00 AM
93jeepyj
They pop up on ebay every now and then. Mine was the same way and I ended up doing a cj7 dash swap, much cheaper and easier to find a replacement stock part though.
93jeepyj is offline
post #5 of 9 Old 08-25-2009, 09:17 AM
mazyj
i just found a rust free one at a junkyard, if you do go this route make sure to get any rust off of it and also consider coating it in some undercoating like i did, this will keep it from rusting and actually eliminates any rattling and noise from it, makes the whole dash feel more solid now. Good Luck, and BTW i paid $25 for mine from a bone-yard.
EDIT - also keep in mind there are slight differences between the model years, i believe the major one to be the speedo/tach gauges are different when they switched to a digital speed sensor from the transfer case. Mine is the old school mechanical speedo wire and my gauges were not a direct fit, i actually just had to drill a few holes and it wasn't a big deal at all but good to know none the less.
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
post #6 of 9 Old 08-25-2009, 09:56 AM
bryris
How do you spot said dash backing? I've had my window down before and only see the plastic backing behind the defrost.
1995 YJ Sahara
bryris is offline
post #7 of 9 Old 08-25-2009, 10:00 AM
93jeepyj
Theres a handful of torx bolts up there that bolt it down to the body tub. Its behind the plastic but you can see where it overlaps the tub. Itll be pretty obvious if its rotten back there with the windshield folded down. I found out how bad mine was when I went to change the cowl seal.
93jeepyj is offline
post #8 of 9 Old 08-25-2009, 11:20 AM
BlueTorch
Its no help but we toss them out when doing a YJ build. I dont have anything coming up soon or I would save you one. Like mentioned above try a salvage yard.
Dan DuBose
Blue Torch FabWorks, Inc.
205-521-7333 OR 866-RCK-CRWL
Check out our Facebook fan page!
[SIGPIC][/SIGPIC]
BlueTorch is offline
post #9 of 9 Old 08-25-2009, 03:27 PM
pasinbuy
Since you are in God's land, Costa Rica I would guess that finding replacement used parts is hard. Plus getting one shipped is taking a chance.
What I did with mine was to template the holes on the old piece then grind all of the rust off. Next step is to weld replacement metal onto the lip. Paint, then you have a new part. Very easy and quick. In fact much quicker than shipping and waiting. If you do bad work, don't worry no one will see it.
Good luck.
pasinbuy is offline
Removing metal dash support write up Bl4cK_kNiF3 YJ Wrangler Technical Forum 14 04-13-2014 07:37 AM
light screech squeal at start up, metal on metal sound not moving rutacon05 TJ Wrangler Technical Forum 3 12-07-2009 01:06 AM
metal dash backing CostaRicaJeep TJ Wrangler Technical Forum 0 08-24-2009 07:53 PM
Is the metal 'dash' part available anywhere? citRon YJ Wrangler Technical Forum 9 08-09-2008 08:18 AM
Swapping metal dash Mark455SD YJ Wrangler Technical Forum 11 05-21-2008 08:07 PM
