Melted Ignition Switch. Now what? - JeepForum.com
post #1 of 12 Old 12-30-2011, 01:29 PM Thread Starter
Nubbs
I have a 90 4.2 and this morning the ignition switch went bad. I had started the jeep just fine and than during warm up it died. When I turned the key again nothing happened. The accessory lights would flash on real quick but thats it. No radio no nothing.
I went to replace it and found the black plug melted into the old switch. After freeing it I can see that a good part of it is pretty melted and so is one of the wires coming out of the plug. I cleaned up the plug as best I could and plugged it into the new switch. Now I have nothing at all. No power to anything. The headlight/dash lights will not even power on. I am at a total loss as wiring is far from a strong suit of mine.
Does anybody have any suggestions?
TIA
I did a search and only came up with melted headlight switches and melted rotors.
Nubbs is offline
post #2 of 12 Old 12-30-2011, 02:17 PM
Mark05059
check for bad fuses if you have no power.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 12 Old 12-30-2011, 02:30 PM Thread Starter
Nubbs
All the fuses are good.
Nubbs is offline
post #4 of 12 Old 12-30-2011, 03:40 PM
40dog
if the head lights don't come on.i think you are not getting power before the key switch. check the wire connections at the power distribution center under the hood.next to the battery. i all most forgot remove clean and reinstall the battery terminals.this should be done first before chasing any electrical problems.did you test the old ignition slide switch with a ohm meter before replacing?
40dog is offline
post #5 of 12 Old 12-30-2011, 04:05 PM Thread Starter
Nubbs
I did clean the battery terminals and make sure the batt had a good charge. I did not check the old switch before removing it. I will check for power next to the battery.
Thanx
Nubbs is offline
post #6 of 12 Old 12-30-2011, 04:21 PM
40dog
do the brake lights work? Do you have a power distribution center next to the battery with the big maxi fuses. if not then it will have fusible links for short protection.
40dog is offline
post #7 of 12 Old 12-30-2011, 05:34 PM Thread Starter
Nubbs
I will check the brake lights on my way out. I do not think I have any maxi fuses that I remember. I have 2 relays and 2 some type of diagnostic plugs next to the battery.
Nubbs is offline
post #8 of 12 Old 12-30-2011, 05:52 PM
40dog
you probably have a fried fusible link then.open your manual look up the fusible links.
40dog is offline
post #9 of 12 Old 12-31-2011, 02:41 PM Thread Starter
Nubbs
I just tried the brakes and they do not work either. Seems like I have now lost all power to the jeep. I will look to see if I can find a PDF of the manual and start following the power flow.
Nubbs is offline
post #10 of 12 Old 12-31-2011, 03:11 PM
Que89YJ
X2 with 40Dog, you burned a fuseable link on the starter solinoid on the firewall.
Que89YJ is offline
post #11 of 12 Old 01-01-2012, 01:57 PM Thread Starter
Nubbs
I am going to try to get that replaced tomorrow and see how things go. Thanks for the help guys.
Nubbs is offline
post #12 of 12 Old 01-01-2012, 06:32 PM
40dog
before you change anythging.check the positive connection at the firewall.if you follow the medium sized red wire from the battery terminal to the fire wall. there is a stud connection there.remove the nut and clean all the wire ring connections .Those connectiona are all the fuse link connections and the stud is the main power to the jeep itself .all power runs thru there except the starter power comes from the larger red positive cable from the bat.im describing this from looking at my 1988 yj yours may be different.
40dog is offline
fan switch melted and other stuff. slafferty TJ Wrangler Technical Forum 8 09-22-2009 02:47 PM
Another melted fan switch question JBTJ TJ Wrangler Technical Forum 0 06-19-2008 12:28 PM
A/C problem. My fan speed switch melted? Lostj TJ Wrangler Technical Forum 2 05-30-2008 03:09 PM
Ignition Rotor Melted?? flip1950 TJ Wrangler Technical Forum 1 01-13-2008 11:31 AM
yet another melted switch lokua TJ Wrangler Technical Forum 3 09-13-2006 06:59 PM
