MEDIC! 87' YJ down! - JeepForum.com
post #1 of 2 Old 08-21-2011, 06:29 PM Thread Starter
CBRNpog
1987 YJ Wrangler
87! 4.2 Start up problems
My 87' 4.2L YJ wrangler chewed up the teeth of 2 new starters in a week and on the one that was on there first the whole nose cone had broken off. When i turn the key is get a loud grinding almost to the point of making my ears ring.
I don't know what the problem is my uncle said its probobly something with the flex plate and someone else said the flywheel was the problem but it doesn't look that too bad and another said the starter wasn't shimed right but I don't think it would happen a twice if that were the case.
Can anyone else help try and pin this one for me, because right now I'm looking at $800 for a clutch job and I really don't want to pay that.
Thanks.
CBRNpog is offline
post #2 of 2 Old 08-21-2011, 09:42 PM
sbsg2005
Could be several issues, after to replaced the starter when you started it did you hear a high pitched whine when you let off the key? If so your started would need shimmed. Did the teeth grind when you first turned the key? If so then the teeth were not engaging properly. Are you sure you are getting the right number of teeth on the starter gear? There should be 9 teeth on the gear if you have a 4.2.
sbsg2005 is offline
4.2l , flex plate , problem , repair , starter
Jeep Medic Tt frankiefire702 TJ Wrangler Technical Forum 1 09-24-2007 01:33 PM
Skid Row or Jeep Medic mountaineerjp TJ Wrangler Technical Forum 27 02-20-2007 12:18 AM
Jeep Medic and Northridge4x4 akjason TJ Wrangler Technical Forum 17 01-28-2007 09:15 AM
Jeep Medic Skids? diveguy TJ Wrangler Technical Forum 9 02-24-2005 04:02 PM
medic TC skid question??? rubi-soho TJ Wrangler Technical Forum 3 01-03-2005 11:30 AM
