Mechanical timing with comp cam... weird compression numbers - JeepForum.com
post #1 of 10 Old 04-09-2013, 07:52 PM Thread Starter
95yj0645
I am trying to start my new 4.6L I built for the yj and it is way out of time. tried setting up the distributor multiple times with no such luck. I finally ran a compression check and I get 50psi on cyl 1 and cyl 6. 2,3,4,5 all have 150 psi. pulled the timing cover and it appeared my chain had moved half a tooth (A to Z brand chain) went and bought a cloyes tonight ( the one I wanted to begin with `). set it up and decided that before I put the cover on I should crank it over and check the compression on those cylinders and they are the exact same, still 50psi. I am running a comp 68-235-4 extreme 4x4 cam. should I try advancing the cam gear ? I am getting frustrated. It has a .030 bore with new pistons and all of my rings were set up and measured exactly the same way. HELP ! this is my only vehicle.
95yj0645 is offline
post #2 of 10 Old 04-09-2013, 09:09 PM Thread Starter
95yj0645
AHHHH! after doing a little more searching on the forum it looks like I timed it on TDC exhaust and not TDC compression now im not sure of my cam position. I guess im going to have to start from scratch tomorrow and pull the valve cover and rotate my cam until both valves are closed on number 1 and then set up my crank. Thank God these are non interference engines..
95yj0645 is offline
post #3 of 10 Old 04-10-2013, 10:00 AM Thread Starter
95yj0645
Bump
'95 YJ, 4.6L stroker, Ford 8.8, AX15, SYE, SOA, Cage kit, full armor, 35" MT/R Kevlar's
95yj0645 is offline
post #4 of 10 Old 04-10-2013, 01:00 PM
youngjeepr
What size cam did you get? What is your ENGINE timing set at?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #5 of 10 Old 04-12-2013, 05:07 AM Thread Starter
95yj0645
Engine timing is stock .. Ended up taking timing chain off and rocker arms off and running a compression test getting terrible results. 1-25psi,2-40psi,3-75psi, 4-150,5-140,6-25psi. I pulled the head and 8 out of 12 valves were leaking after my supposed valve job I paid for! Here are some pics after I filled the head with water and set it on it's side.
95yj0645 is offline
post #6 of 10 Old 04-12-2013, 08:27 AM
Siva283
I would have used oil not water. You can already see the rust forming. Load that pupy up with some kind of oil to get the moisture out. I would also take it back and have the valve job redone on thier dime since they half ***** it.
Ask me how I know...
Siva283 is offline
post #7 of 10 Old 04-12-2013, 08:46 AM
youngjeepr
Wouldn't oil be to thick? I've always used water or coolant
post #8 of 10 Old 04-12-2013, 09:15 AM
Jeepsr4me
No u use ALCOHOL ..... Not water... or oil.. Oil to thick.
I have verified 100s of valves and alcohol will not pass by a good seal.
Jeepsr4me is offline
post #9 of 10 Old 04-13-2013, 04:47 AM Thread Starter
95yj0645
Who wants to waste alcohol .. Nonetheless I took the head back and they went through it again and it's ready to be picked up (they cleaned the rust ). They did however try telling me a slight amount of seepage is normal until the valves wear in (after the engine runs for awhile). However, I feel like that was a bit excessive , considering it only took about 5 min for cyl 1 and cyl 6 to start leaking that bad.
95yj0645 is offline
post #10 of 10 Old 04-13-2013, 05:15 AM
Jeepsr4me
You may need to find another machinist. Once you lap those valves in, they seal pretty good.
Rubbing alcohol is what I use... You no drink that..
