Mechanical fuel pump upgrade - JeepForum.com
post #1 of 17 Old 11-29-2012, 11:09 AM Thread Starter
Renegad87
1987 YJ Wrangler
I have a 1987 Jeep Wrangler with the inline six and a weber 38 on it and I want to get ride of the mechanical fuel pump and go with an electric one. Does anyone know the best way to do this? Is there a kit?
Renegad87 is offline
post #2 of 17 Old 11-29-2012, 04:49 PM
laffman
This is what I run in my Jeep.
Carter Fuel Pump
Holley Safety Switch
Painless Performance Pump Relay
1990 Jeep YJ Laredo 4.2 I-6
2010 Jeep JK Islander 3.8 V-6
1982 Jeep CJ-8 Scrambler 304 V-8
laffman is online now
post #3 of 17 Old 11-29-2012, 05:13 PM
uhohthe50
Subscribed.. I'm curious about this too
uhohthe50 is offline
post #4 of 17 Old 11-29-2012, 07:18 PM
uhohthe50
Originally Posted by laffman View Post
What did you put in place of the old mechanical pump?
post #5 of 17 Old 11-29-2012, 07:51 PM
Old4X
1990 CJ7
Block off plates are available. But The mechanical fuel pump is the most reliable way to feed a carb. The only use I would have for an elect pump is as a boost pump for starting after sitting a week or more.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #6 of 17 Old 11-29-2012, 09:34 PM
uhohthe50
I think I found it:
http://www.summitracing.com/parts/sum-402035
post #7 of 17 Old 11-30-2012, 09:57 AM
booboowv77
I would leave the mechanical on as a back up in case the electric one fails.
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #8 of 17 Old 11-30-2012, 10:05 AM
Jax89Jeeper
If you don't disconnect the fuel lines, the mech pump will act as a restricion to the elec pump and if the mech pump is over powered you'd blow the diaphragm. If you disconnect the fuel lines and leave it in place, it will fail fom being ran dry. The fuel coming thru cools the pump much like it does an electric one. IMO the Mech fuel pump is an advantage over electric and would leave it in place (K.I.S.S. method). A mech pump is much less likely to fail and your carb does not need any more fuel pressure than what it provides. If you must go electric, get a block off plate.
Jax89Jeeper is offline
post #9 of 17 Old 11-30-2012, 10:47 AM
Jeepsr4me
You can get these 7 psi pumps at just about any parts house. Last one I bought was like 22 bucks, even came with a inline filter before it. Remember electric pumps like to push fuel not pull it. So mount it LOW like on the frame rail. I never liked the mech ones on the block. WHEN they leak, they always do, they fill the oil pan full of fuel and ruin bearings.
Jeepsr4me is offline
post #10 of 17 Old 11-30-2012, 04:52 PM
booboowv77
Sorry I swore I read it somewhere about leaving the Mechanical on as a backup would work. Good to know it won't.
Just my toy!
post #11 of 17 Old 11-30-2012, 07:08 PM
Jax89Jeeper
Well you can leave it inplace to plug the hole..... but it would not be of any use as a back-up.
post #12 of 17 Old 12-01-2012, 09:53 AM Thread Starter
Renegad87
1987 YJ Wrangler
Awesome thanks for the info. Another question I'd like to ask is the order of components starting from the tank. My current understanding follows this setup:
Tank
Fuel Pump w/integrated filter (Mounted by tank)
Fuel Filter w/return line (Engine Bay)
Fuel Pressure Regulator w/gauge (Engine Bay)
Carb
Some people have placed the FPR before the filter and I don't see why.
post #13 of 17 Old 12-02-2012, 08:44 AM
Ksyrium
1987 YJ Wrangler
Tank
Carb
It is my understanding is that if you use the Carter fuel pump, you should not need the regulator.
I read about that here
ΜΟΛΩΝ ΛΑΒΕ
Ksyrium is offline
post #14 of 17 Old 12-03-2012, 11:02 AM
laffman
Tank
Carb
With my Carter pump, I run a filter between the tank and the pump. The Carter doesn't have an intgrated filter. The rest of your setup looks just like mine.
I still needed the regulator with my Carter pump. It's pushing 6 psi, which is too much for my Weber 38. It was flooding. I installed a Redline regulator. I'm running 3 psi now.
Redline regulator
post #15 of 17 Old 12-03-2012, 05:15 PM
Jax89Jeeper
Redline regulator
Yeah, with the Weber carbs, any fuel pump needs a regulator.... Even the stock unit.
