MC2150 + HEI Upgrade Makes Moose Happy - Page 6 - JeepForum.com
post #76 of 94 Old 01-22-2007, 01:04 PM Thread Starter
atomicmoose
Just call me Moose
atomicmoose's Avatar
Quick update: Put the HEI in this weekend and I couldn't be happier. After fiddling with the timing and such she seems to run very strong.
I have to adjust the carb again as I am getting a pretty strong unburnt gas smell, but that is minor and I will tackle that today.
Thanks to all who helped me along the way.
atomicmoose is offline
post #77 of 94 Old 01-22-2007, 05:22 PM
drespecki
1983 CJ7
Moose, where did you get the adapter plate? My 2100 has the square back edge like your plate yet the summit adapter is curved. Where can one get that adapter you have? Thanks...
drespecki is offline
post #78 of 94 Old 01-23-2007, 09:45 AM Thread Starter
atomicmoose
Just call me Moose
Mine came withe the "kit" I bought.
post #79 of 94 Old 01-23-2007, 11:11 AM Thread Starter
atomicmoose
Just call me Moose
Questions:
On the ride to work this morning, throttle response was "sluggish". When I give her some gas, it seems to bog for just a half second or so, and then I get a surge and she rips. Is this a timing thing or an air/fuel mixture thing? I think I am a tad lean in my mixture right now... I made it that way on purpose as it seems to run well at this setting and it keeps the fumes bearable. Timing is about 10* BTDC. Idle is very strong, even when it is very cold.
Thoughts?
post #80 of 94 Old 01-25-2007, 08:22 AM Thread Starter
atomicmoose
Just call me Moose
Bump! Or should I start a new thread with these questions?
post #81 of 94 Old 01-25-2007, 10:38 AM
RockWoRM
RockWoRM's Avatar
Yup... start a new thread... no one (me) likes to read through all 6 pages!!!
besides... I have a 4.0!
WoRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #82 of 94 Old 01-25-2007, 11:17 AM
drexelsteve
that sounds like a carb issue. I'd be willing to bet that it's the choke adjustment. Actually, mine does that every once in a while when it's cold and wet out. It got better after i adjusted the choke a bit, but it's still there. Usually i just let it warm up a little longer on those days.
13 Rubi
drexelsteve is offline
post #83 of 94 Old 01-25-2007, 02:47 PM Thread Starter
atomicmoose
Just call me Moose
Funny thing is, it happens after it is warmed up. I have a manual choke as well, so I can control that in cab.
RockWorm, change your view and it's only two pages.
post #84 of 94 Old 01-25-2007, 08:19 PM
drespecki
1983 CJ7
Hey Moose..did you use the trans-kickdown lever on your 2150 or did you use the stock YJ mechanism with the throttle cable pulling downward? My YJ is auto but the carb I have, the 2100 is virtually perfect but without the kickdown lever. I don't really need it, do I?
post #85 of 94 Old 01-25-2007, 08:44 PM Thread Starter
atomicmoose
Just call me Moose
I used the stock downward pulling linkage.
It can be seen here(kinda):
post #86 of 94 Old 01-25-2007, 08:47 PM
drespecki
1983 CJ7
Are you auto or stick?
post #87 of 94 Old 01-25-2007, 08:48 PM Thread Starter
atomicmoose
Just call me Moose
Manual
10 chars
post #88 of 94 Old 01-26-2007, 03:38 PM
King03Kev
King03Kev's Avatar
1987 YJ Wrangler
On my Weber I had a similar problem, changed the idle jet and smell and stumble went away.
kevyj87 '87 I6 5spd, 215,000+ miles, Herced, Nuttered, Weber, HEI, RE 4", 1" BL, 4:11's, np231, 33x12.5's, SYE & shaft, 1" brown dog mm, home made bumpers front & rear, Ramsey 8,000lb winch
King03Kev is offline
post #89 of 94 Old 01-26-2007, 03:43 PM Thread Starter
atomicmoose
Just call me Moose
My 2150 has the #47 jets in it already, I think....
Someone in another thread mentioned fuel pressure. Would that cause this problem?
post #90 of 94 Old 01-27-2007, 03:44 PM
King03Kev
King03Kev's Avatar
1987 YJ Wrangler
I guess too much fuel pressure could cause it to load up/flood float bowl. When anyone installs a Weber they suggest a regulator set at 3-3.5psi, cheap enough to see if it's the problem.
MC2150 upgrade Vacuum line looke right? Matsuno YJ Wrangler Technical Forum 3 05-25-2009 11:37 PM
new gears = makes me happy ballallday89 Wrangler General Discussion 4 03-17-2009 01:37 AM
Hunting Moose with a TJ (Lighting question) canuck_bob TJ Wrangler Technical Forum 5 08-13-2008 02:21 PM
Some help with a MC2150 MetZenDS YJ Wrangler Technical Forum 26 09-15-2007 01:48 PM
help mc2150 volcom3375 YJ Wrangler Technical Forum 9 11-24-2006 10:38 PM
